JohnDoe57 0 Posted ... Just became a member today but I can't seem to connect to any server. The connection keeps on getting terminated. It's just running a loop really. I've reset my hosts file via this link: http://osxdaily.com/2014/04/12/restore-original-hosts-file-mac/But still no luck...Running OS X 10.8.5. 2015.02.25 19:04:11 - Updating systems & servers data .... 2015.02.25 19:04:12 - Systems & servers data update completed! 2015.02.25 19:04:44 - Activation of Network Lock - OS X - PF. 2015.02.25 19:04:44 - OS X - PF rules updated, reloadingI 2015.02.25 19:04:48 - Session starting.I 2015.02.25 19:04:48 - Installing tunnel driverI 2015.02.25 19:04:48 - Checking authorization ...! 2015.02.25 19:04:49 - Connecting to Kraz (Canada, Toronto, Ontario). 2015.02.25 19:04:49 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015. 2015.02.25 19:04:49 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08. 2015.02.25 19:04:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2015.02.25 19:04:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2015.02.25 19:04:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.25 19:04:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.25 19:04:49 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]. 2015.02.25 19:04:49 - OpenVPN > UDPv4 link local: [undef]. 2015.02.25 19:04:49 - OpenVPN > UDPv4 link remote: [AF_INET]199.19.94.61:443. 2015.02.25 19:04:49 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.94.61:443, sid=227f7712 1770586e. 2015.02.25 19:04:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2015.02.25 19:04:49 - OpenVPN > Validating certificate key usage. 2015.02.25 19:04:49 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2015.02.25 19:04:49 - OpenVPN > VERIFY KU OK. 2015.02.25 19:04:49 - OpenVPN > Validating certificate extended key usage. 2015.02.25 19:04:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2015.02.25 19:04:49 - OpenVPN > VERIFY EKU OK. 2015.02.25 19:04:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2015.02.25 19:04:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2015.02.25 19:04:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.25 19:04:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2015.02.25 19:04:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.25 19:04:50 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA. 2015.02.25 19:04:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.94.61:443. 2015.02.25 19:04:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2015.02.25 19:04:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.43.94 10.4.43.93'. 2015.02.25 19:04:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2015.02.25 19:04:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2015.02.25 19:04:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2015.02.25 19:04:52 - OpenVPN > OPTIONS IMPORT: route options modified. 2015.02.25 19:04:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2015.02.25 19:04:52 - OpenVPN > dyld: lazy symbol binding failed: Symbol not found: ___strlcpy_chk. 2015.02.25 19:04:52 - OpenVPN > Referenced from: /Applications/AirVPN.app/Contents/MacOS/openvpn. 2015.02.25 19:04:52 - OpenVPN > Expected in: /usr/lib/libSystem.B.dylib. 2015.02.25 19:04:52 - OpenVPN >. 2015.02.25 19:04:52 - OpenVPN > dyld: Symbol not found: ___strlcpy_chk. 2015.02.25 19:04:52 - OpenVPN > Referenced from: /Applications/AirVPN.app/Contents/MacOS/openvpn. 2015.02.25 19:04:52 - OpenVPN > Expected in: /usr/lib/libSystem.B.dylib. 2015.02.25 19:04:52 - OpenVPN >! 2015.02.25 19:04:53 - Disconnecting. 2015.02.25 19:04:53 - Connection terminated. Quote Share this post Link to post
Staff 9751 Posted ... Hello! Eddie client can run on OS X Mavericks and Yosemite only. Older OS X versions should run Tunnelblick, which is free and open source as well. Instructions for Tunnelblick are in the usual OS X page, in our web site click "Enter" -> "Mac OS X". You might even consider to upgrade your system, if possible. Kind regards Quote Share this post Link to post
JohnDoe57 0 Posted ... Ahhh perfect! Running smoothly now! Thanks! Quote Share this post Link to post
mrizzo 0 Posted ... Hello, I know I'm bringing up an old post however I am experiencing the same problem yet I am running Yosemite. Any thoughts would be appreciated,Thank you Quote Share this post Link to post
ulemulle 0 Posted ... Hello, I know I'm bringing up an old post however I am experiencing the same problem yet I am running Yosemite. Any thoughts would be appreciated,Thank youSame here on yosemite Quote Share this post Link to post
jR0ny 0 Posted ... Hello, I know I'm bringing up an old post however I am experiencing the same problem yet I am running Yosemite. Any thoughts would be appreciated,Thank youSame here on yosemitesame here ... Quote Share this post Link to post
mrizzo 0 Posted ... Seems a few of us are having the same issue here. Should we just skip Eddie and use Tunnelblick? I used Tunnelblick last year and had mixed results. Hoping Eddie would be a better option. Quote Share this post Link to post
eusebio1 0 Posted ... Any news? VPN service is currently not usable due to the problem. Using Tunnelblick unfortunately doesn't help - please fix the issue, otherwise using AirVPN doesn't make much sense to me anymore... Quote Share this post Link to post
