Not connected, Your IP: 216.73.216.51
gijo
ANSWERED Unable to connect using DD-WRT (TLS_ERROR)
I am using DD-WRT v24-sp2 (01/04/15) big on a Linksys E1200v2.
I wanted to connect to Acrux server in Netherlands (37.48.81.12) by UDP on 443.
I followed the instruction provided here: https://airvpn.org/ddwrt/
but I have an error in my OpenVPN log.
Clientlog:
20150108 22:47:39 N TLS_ERROR: BIO read tls_read_plaintext error: error:140830B5:lib(20):func(131):reason(181)
20150108 22:47:39 N TLS Error: TLS object -> incoming plaintext read error
20150108 22:47:39 N TLS Error: TLS handshake failed
20150108 22:47:39 I SIGUSR1[soft tls-error] received process restarting
20150108 22:47:39 Restart pause 2 second(s)
20150108 22:47:41 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
ca /tmp/openvpncl/ca.crt cert /tmp/openvpncl/client.crt key /tmp/openvpncl/client.key management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto udp cipher aes-256-cbc auth sha1 remote 37.48.81.12 443 comp-lzo yes tls-client tun-mtu 1500 mtu-disc yes ns-cert-type server fast-io tun-ipv6 tls-auth /tmp/openvpncl/ta.key 1 tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA256
Am I doing some mistake or do you have any idea?
Thanks.
Wrong TLS cipher: TLS-DHE-RSA-WITH-AES-256-CBC-SHA256
Try with "None". If it does not work try with "TLS-DHE-RSA-WITH-AES-128-CBC-SHA". Both are wrong as well but for some bug in several DD-WRT builds either the first OR the second work.
Thanks, it did not work with "None" but was ok with "TLS-DHE-RSA-WITH-AES-128-CBC-SHA".
Thanks very much for you quick reply.
Bests
Had the same issue with configuring my new router. I can confirm that changing the TLS setting to "TLS-DHE-RSA-WITH-AES-128-CBC-SHA" works just fine!
