Not connected, Your IP: 3.135.202.224
qazwsxxswzaq
Using AirVPN with Android [SOLVED]
So I tried the following instructions (on a rooted tablet connected to my WI-FI),
Using AirVPN with Android :
https://airvpn.org/index.php?option=com_content&view=article&id=63&Itemid=126
Everything works fine up until the point when I run openVPN on the android device. It will not allow me to select air.ovpn as the openvpn tunnel. I tried different configuration files, but to no avail.
Anyone get this to work on android device over WIFI?
Cheers,
qaz
EDIT:
Not sure what happen, but after fiddling around a bit (installing other openVPN software), it finally seemed to work (not sure why...).
