Not connected, Your IP: 3.140.242.165
betacat
Tunnelblick Connection Reverts To "Authorizing"
I'm using Tunnelblick with OSX 10.4.11 on an old Mac G4 to connect via Vuse. Everything has worked fine for many months but now a problem has cropped up.
I can connect to any server and the connection is OK for about 6-8 hours, then Tunnelblick consistently displays "Authorizing" instead of "Connected" status, even though an IP check appears to show that it's still connected.
How can I fix this?
...Thanks.
After applying the latest beta update to Tunnelblick, it seems to be working now... 10 hours and no disconnects so far
The problem is back
If I generate a new Tunnelblick configuration (and select "Resolved hosts in .ovpn file" & "All servers for area or region"), connections work reliably for a few days or so, then start to fail intermittently.
I am not using a firewall or any other blocking software. Anyone have any ideas?
