Cyterstp 1 Posted ... Just switched to AirVPN because it seems like it has the best functionality. But, we need a dark mode icon for the menu bar, and the ability to hide the icon from the dock. I would like to be able to access the main window from just the menu bar. 1 airvpn_user_45569350664 reacted to this Quote Share this post Link to post
Staff 10483 Posted ... Hello! About the Dark mode, it's a new Yosemite feature that's not well documented.From what we understand, in Dark mode, only AirVPN app still remains with the menubar in Light mode because it's running with elevated privileges. When you specify the Dark mode in System Preferences > General, it will be valid only for the standard user, not the elevated user.You can try to runsudo defaults write /Library/Preferences/.GlobalPreferences AppleInterfaceStyle Darkto enable Dark mode on ALL users, after that AirVPN will start in Dark mode. The icon will not be visible, sorry. The next version will have an icon compatible to both Dark and Light mode.We currently don't understand well how this impacts the standard user settings. If you notice problems, revert withsudo defaults write /Library/Preferences/.GlobalPreferences AppleInterfaceStyle LightTo view the current setting:sudo defaults read /Library/Preferences/.GlobalPreferences AppleInterfaceStyle About the ability to hide the icon from the dock: it seems not possible to show/hide that icon at runtime. Do you know an application that have this kind of options in its preferences? For example uTorrent has this option in Windows, but not under OS X. Kind regards Quote Share this post Link to post
zhang888 1067 Posted ... Hello Staff,It can be accomplished on OS X this way: http://www.cnet.com/news/prevent-an-applications-dock-icons-from-showing-in-os-x/ uTorrent does that on purpose, to show download speeds etc. An example for an app that doesn't use any Dock icons is - Viscosity, NZBget (Probably many others, I just can't remember right now) Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
psychlops 28 Posted ... Some apps that hide the dock icon:WeatherBug (Free) http://weather.weatherbug.com/weatherbug-apps.htmlsmcFanControl (Free) http://www.macupdate.com/app/mac/23049/smcfancontrolCookie (Demo) http://www.macupdate.com/app/mac/37084/cookie But this might provide the most help... I use a mac program called SpamSieve http://www.macupdate.com/app/mac/9116/spamsieveand by default the dock icon is visible. Here are their instructions for hiding it: How can I hide SpamSieve’s Dock icon?Hold down the Control key and click on the SpamSieve icon in the Finder. Choose Show Package Contents from the menu. Open the Contents folder, and then open the Info.plist file using TextEdit. At the bottom of Info.plist, change:<key>LSUIElement</key><string>0</string>to:<key>LSUIElement</key><string>1</string>(That is, just change the 0 to 1.) Then save the Info.plist file and relaunch SpamSieve. You may need to temporarily move the SpamSieve application to the desktop and double-click it there in order for Mac OS X to notice that you now want the Dock icon hidden. To make SpamSieve’s Dock icon visible again, change the Info.plist file back; that is, change the 1 back to 0.Hope this helps! Quote Share this post Link to post
Staff 10483 Posted ... The improvement has been addressed in the latest experimental build. Please check it: https://airvpn.org/topic/13002-experimentalbeta-release/ Quote Share this post Link to post
