Not connected, Your IP: 18.225.31.159
grifter
openSuse 13.2: AirVPN Network Lock Doesn't Work
In the last release the network lock worked just fine but now when I look at iptables there's nothing there.
Also the client does a bit of crashing from time to time.
I can only use the portable version of the client but the network lock is working fine. I wasn't satisfied with how the network manager behaved so I disabled it. I don't have a graphical user interface anymore but I also didn't have problems with the client anymore. Also, no crashes so far.
I did add the rules manually in 13.1 but this time I decided to go with the automatic setup and it works. When I log off a server I cannot access the internet. The network lock behaves like it should be.
Maybe I will try the network manager again some time in the future but for now I am satisfied.
There's one thing I cannot get rid of: When updating the systems & server data I often get the following message:
OpenVPN > write UDPv4: Operation not permitted (code=1)
sometimes 20 lines but in the end it always works.
Cheers.
wer
PS: Just a passing comment:
The portable version of Eddie 2.7 and the network lock also work perfectly fine under Arch Linux 64 Bit!
