Not connected, Your IP: 3.138.141.202
Greetings,
I am attempting to forward a port through the client interface on the website to use for P2P. I choose TCP/UDP and a port, which was available, and it says it is forwarded. However, when I hit the button to "Check" the little light stays grey and says "Not reachable on server IP over the external port XXXXX, tcp protocol. Error : 110 - Connection timed out - Checked 0 seconds ago".
I am connected to AirVPN at the time.
I tried disabling Windows Firewall, which I can't imagine has anything to do with it, and also the SIP firewall on my router. Also have it set to open. Doesn't make a difference.
I am also getting messages in Vuse that I am firewalled, even though I have set the static inbound port properly to what I forwarded on the website.
Something clearly isn't happening but I am at a loss.
Just an update: Running a speed test on any connected AirVPN server through the client page interface shows In-Tunnel Speed: 0 - error - as well.
Are you sure your P2P software is running and using the forwarded port?
If you're using NoScript, disable ABE or the whole add-on.
