Hi
I am running fedora and airvpn with nothing else no proxys ect all up to date
I have just checked ipleak.net and have noticed this???
Will some one please tell me what this means
Posted 27 October 2014 - 09:26 PM
Can you please tell us:
- how do you connect (with our client Eddie, with OpenVPN directly...), to which port and using what procotol?
- which browser do you run?
- is the browser configured to connect to a proxy? is the client Eddie or OpenVPN configured to connect over a proxy?
- does the reported outcome occur with any browser you try?
- is the showed IP address coming from the network you're connected to, or is it an IP address you don't know at all?
Can you send us the logs of the software you use to connect (our client Eddie, OpenVPN...)?
Posted 28 October 2014 - 01:41 AM
Eddie
firefox 33 on *nix
No it is not configuerd to connect to a proxy
I have not tried with other browsers
I do not know this ip at all
I am using an addon called random agent spoofer could this be the problem?
Posted 28 October 2014 - 01:52 PM
Eddie
firefox 33 on *nix
Yes, the addon will spoof info in the browser packets. However it is not a problem at all under a leak point of view, the add-on does not add in any part of your http packets your "real" IP address.
Topic | Forum | Started By | Stats | Last Post Info | |
Eddie For Android Quick Connect Does Not Fallback To Other Protocols |
Eddie - AirVPN Client | kah0922 |
I will be trying NordVPN, AirVPN, and ProtonVPN this weekend and will post some speed results |
Other VPN competitors or features | Pankh |
"You'll need internet for this" Microsoft Services when using SSL Tunnel |
Troubleshooting and Problems | Pankh |
"You'll need internet for this" Microsoft Services when using SSL Tunnel![]() |
Troubleshooting and Problems | free_refil |
Nexus 6P Eddie Does not Connect |
Troubleshooting and Problems | DonTurco |
Community →
Troubleshooting and Problems →
IPv6 problems with server LichStarted by Jeremyx3, 05 Jan 2019 ![]() |
Community →
General & Suggestions →
SOCKS proxy question and availabilityStarted by routeninja, 28 Dec 2018 ![]() |
Community →
AirVPN keeps trying to connect but keeps disconectingStarted by HPdrum, 22 Nov 2018 ![]() |
Community →
AirVPN & DWS (Destorying Windows 10 Spying)Started by unv, 31 Oct 2018 ![]() |
Community →
Twin instance, Hyper-V port routing issueStarted by Mufasa, 30 Jul 2018 ![]() |
0 members, 1 guests, 0 anonymous users
