Not connected, Your IP: 3.147.104.120
Hi All. I am a noob if it goes about VPN. I have installed AirVpn client and I try to connect to a server in Netherland, but just after I'm connected client disconnects and tries to reconnect. Any ideas what cause it? I work on Windows 7 Enterprise 64bit. I'm attaching my log.
Thank you for your help.
I 2014.10.19 00:52:16 - Session starting.
! 2014.10.19 00:52:16 - Checking environment
! 2014.10.19 00:52:17 - Checking authorization
! 2014.10.19 00:52:17 - Connecting to Grafias (Netherlands, Amsterdam)
. 2014.10.19 00:52:17 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 18 2014
. 2014.10.19 00:52:17 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.10.19 00:52:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.10.19 00:52:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.10.19 00:52:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.19 00:52:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.19 00:52:17 - OpenVPN > Socket Buffers: R=[8192->8192] S=[64512->64512]
. 2014.10.19 00:52:17 - OpenVPN > UDPv4 link local: [undef]
. 2014.10.19 00:52:17 - OpenVPN > UDPv4 link remote: [AF_INET]62.212.72.175:443
. 2014.10.19 00:52:17 - OpenVPN > TLS: Initial packet from [AF_INET]62.212.72.175:443, sid=127a7e95 c34d41a3
. 2014.10.19 00:52:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.10.19 00:52:18 - OpenVPN > Validating certificate key usage
. 2014.10.19 00:52:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.10.19 00:52:18 - OpenVPN > VERIFY KU OK
. 2014.10.19 00:52:18 - OpenVPN > Validating certificate extended key usage
. 2014.10.19 00:52:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.10.19 00:52:18 - OpenVPN > VERIFY EKU OK
. 2014.10.19 00:52:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.10.19 00:52:21 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.10.19 00:52:21 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.19 00:52:21 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.10.19 00:52:21 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.19 00:52:21 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.10.19 00:52:21 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.212.72.175:443
. 2014.10.19 00:52:23 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.10.19 00:52:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.19.230 10.4.19.229'
. 2014.10.19 00:52:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.10.19 00:52:24 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.10.19 00:52:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.10.19 00:52:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.10.19 00:52:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.10.19 00:52:24 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.10.19 00:52:24 - OpenVPN > open_tun, tt->ipv6=0
. 2014.10.19 00:52:24 - OpenVPN > TAP-WIN32 device [Połączenie lokalne 3] opened: \\.\Global\{BADF76DC-0AFB-4AEC-9AE7-AD0F2616AAE2}.tap
. 2014.10.19 00:52:24 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.10.19 00:52:24 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.19.230/255.255.255.252 on interface {BADF76DC-0AFB-4AEC-9AE7-AD0F2616AAE2} [DHCP-serv: 10.4.19.229, lease-time: 31536000]
. 2014.10.19 00:52:24 - OpenVPN > Successful ARP Flush on interface [31] {BADF76DC-0AFB-4AEC-9AE7-AD0F2616AAE2}
. 2014.10.19 00:52:29 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2014.10.19 00:52:29 - OpenVPN > C:\Windows\system32\route.exe ADD 62.212.72.175 MASK 255.255.255.255 192.168.1.254
. 2014.10.19 00:52:29 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2014.10.19 00:52:29 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2014.10.19 00:52:29 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.19.229
. 2014.10.19 00:52:29 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2014.10.19 00:52:29 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.19.229
. 2014.10.19 00:52:29 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.19.229
. 2014.10.19 00:52:29 - Starting Management Interface
. 2014.10.19 00:52:29 - OpenVPN > Initialization Sequence Completed
! 2014.10.19 00:52:29 - Flushing DNS
W 2014.10.19 00:52:30 - Tunnel not ready, interface status: Down
. 2014.10.19 00:52:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2014.10.19 00:52:30 - Disconnecting
. 2014.10.19 00:52:30 - Management - Send 'signal SIGTERM'
. 2014.10.19 00:52:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2014.10.19 00:52:30 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2014.10.19 00:52:30 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2014.10.19 00:52:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.19.229
. 2014.10.19 00:52:35 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2014.10.19 00:52:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 62.212.72.175 MASK 255.255.255.255 192.168.1.254
. 2014.10.19 00:52:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.19.229
. 2014.10.19 00:52:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.19.229
. 2014.10.19 00:52:35 - OpenVPN > Closing TUN/TAP interface
. 2014.10.19 00:52:35 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2014.10.19 00:52:35 - Connection terminated.
I 2014.10.19 00:52:37 - Cancel requested.
I 2014.10.19 00:52:37 - Session terminated.
This:
is probably a bug fixed in Eddie 2.5 (see the changelog). Please upgrade to Eddie 2.7 stable.
Hi. I have uninstalled Eddie 2.4 and I have installed Eddie 2.7. Now client tries to log in but it is timed out. Please see below for the log:
I 2014.10.19 19:03:16 - AirVPN client version: 2.7, System: Windows, Architecture: x64
. 2014.10.19 19:03:17 - Reading options from C:\Users\cerber\AppData\Local\AirVPN\AirVPN.xml
. 2014.10.19 19:03:17 - Data Path: C:\Users\cerber\AppData\Local\AirVPN
. 2014.10.19 19:03:17 - App Path: C:\Program Files\AirVPN
. 2014.10.19 19:03:17 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2014.10.19 19:03:17 - Command line arguments: path="home"
. 2014.10.19 19:03:17 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2014.10.19 19:03:17 - OpenVPN Driver - TAP-Windows Adapter V9
I 2014.10.19 19:03:17 - OpenVPN - Version: OpenVPN 2.3.4 (C:\Program Files\AirVPN\openvpn.exe)
I 2014.10.19 19:03:17 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2014.10.19 19:03:17 - SSL - Version: stunnel 4.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2014.10.19 19:03:17 - IPV6: Available
! 2014.10.19 19:03:17 - Ready
! 2014.10.19 19:03:24 - Checking login ...
. 2014.10.19 19:03:35 - Checking login ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:03:45 - Checking login ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:03:55 - Checking login ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:04:05 - Checking login ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:04:15 - Checking login ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:04:25 - Checking login ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:04:35 - Checking login ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:04:45 - Checking login ..., 8° try failed (Upłynął limit czasu operacji)
F 2014.10.19 19:04:45 - Cannot login. (Upłynął limit czasu operacji)
! 2014.10.19 19:05:02 - Checking login ...
. 2014.10.19 19:05:12 - Checking login ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:05:22 - Checking login ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:05:32 - Checking login ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:05:42 - Checking login ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:05:52 - Checking login ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:06:02 - Checking login ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:06:12 - Checking login ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:06:22 - Checking login ..., 8° try failed (Upłynął limit czasu operacji)
F 2014.10.19 19:06:22 - Cannot login. (Upłynął limit czasu operacji)
! 2014.10.19 19:06:30 - Checking login ...
. 2014.10.19 19:06:40 - Checking login ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:06:50 - Checking login ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:07:00 - Checking login ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:07:10 - Checking login ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:07:20 - Checking login ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:07:30 - Checking login ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:07:40 - Checking login ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:07:50 - Checking login ..., 8° try failed (Upłynął limit czasu operacji)
F 2014.10.19 19:07:50 - Cannot login. (Upłynął limit czasu operacji)
! 2014.10.19 19:08:29 - Checking login ...
. 2014.10.19 19:08:39 - Checking login ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:08:49 - Checking login ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:08:59 - Checking login ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:09 - Checking login ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:17 - Updating systems & servers data ...
. 2014.10.19 19:09:19 - Checking login ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:27 - Updating systems & servers data ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:29 - Checking login ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:37 - Updating systems & servers data ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:39 - Checking login ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:47 - Updating systems & servers data ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:09:49 - Checking login ..., 8° try failed (Upłynął limit czasu operacji)
F 2014.10.19 19:09:49 - Cannot login. (Upłynął limit czasu operacji)
. 2014.10.19 19:10:05 - Updating systems & servers data ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:10:15 - Updating systems & servers data ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:10:25 - Updating systems & servers data ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:10:35 - Updating systems & servers data ..., 7° try failed (Upłynął limit czasu operacji)
! 2014.10.19 19:10:36 - Checking login ...
. 2014.10.19 19:10:45 - Updating systems & servers data ..., 8° try failed (Upłynął limit czasu operacji)
W 2014.10.19 19:10:45 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (Upłynął limit czasu operacji)
. 2014.10.19 19:10:46 - Checking login ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:10:56 - Checking login ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:06 - Checking login ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:16 - Checking login ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:26 - Checking login ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:36 - Checking login ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:45 - Updating systems & servers data ...
. 2014.10.19 19:11:46 - Checking login ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:55 - Updating systems & servers data ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:11:56 - Checking login ..., 8° try failed (Upłynął limit czasu operacji)
F 2014.10.19 19:11:56 - Cannot login. (Upłynął limit czasu operacji)
. 2014.10.19 19:12:05 - Updating systems & servers data ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:12:15 - Updating systems & servers data ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:12:25 - Updating systems & servers data ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:12:35 - Updating systems & servers data ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:12:45 - Updating systems & servers data ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:13:05 - Updating systems & servers data ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:13:15 - Updating systems & servers data ..., 8° try failed (Upłynął limit czasu operacji)
W 2014.10.19 19:13:15 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (Upłynął limit czasu operacji)
. 2014.10.19 19:14:15 - Updating systems & servers data ...
. 2014.10.19 19:14:25 - Updating systems & servers data ..., 1° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:14:35 - Updating systems & servers data ..., 2° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:14:45 - Updating systems & servers data ..., 3° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:14:55 - Updating systems & servers data ..., 4° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:15:05 - Updating systems & servers data ..., 5° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:15:15 - Updating systems & servers data ..., 6° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:15:25 - Updating systems & servers data ..., 7° try failed (Upłynął limit czasu operacji)
. 2014.10.19 19:15:35 - Updating systems & servers data ..., 8° try failed (Upłynął limit czasu operacji)
W 2014.10.19 19:15:35 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (Upłynął limit czasu operacji)
It appears that Eddie packets are completely blocked. All the 8 attempts against censorship performed by Eddie fail. Please check your firewall or any other program that might be blocking them.
Just upgraded from 1.9 to 2.7 32-bit running on XP and i'm getting the same errors as above.
Was previously getting this on 1.9 hence getting Eddie: https://airvpn.org/topic/13168-the-underlying-connection-was-closed-an-unexpected-error-occurred-on-a-send/
Based on this thread i turned off Windows Firewall, Comodo and AVG and tried again with no change. Please advise
Additional log information - i see that the OpenVPN driver isn't available? I downloaded OpenVPN separately and ran the install - which went through [apparently] but still seeing the error in Eddie.
I 2015.01.09 21:10:24 - AirVPN client version: 2.7, System: Windows, Architecture: x86
. 2015.01.09 21:10:25 - Reading options from C:\AirVPN\AirVPN.xml
. 2015.01.09 21:10:25 - Profile options not found, using defaults.
. 2015.01.09 21:10:25 - Data Path: C:\AirVPN
. 2015.01.09 21:10:25 - App Path: C:\AirVPN
. 2015.01.09 21:10:25 - Executable Path: C:\AirVPN\AirVPN.exe
. 2015.01.09 21:10:25 - Command line arguments:
. 2015.01.09 21:10:26 - Operating System: Microsoft Windows NT 5.1.2600 Service Pack 3
E 2015.01.09 21:10:26 - OpenVPN Driver - Not available
I 2015.01.09 21:10:26 - OpenVPN - Version: Access is (C:\AirVPN\openvpn.exe)
I 2015.01.09 21:10:26 - SSH - Version: Access is denied (C:\AirVPN\plink.exe)
I 2015.01.09 21:10:26 - SSL - Version: Access is (C:\AirVPN\stunnel.exe)
I 2015.01.09 21:10:26 - IPV6: Not available
. 2015.01.09 21:10:26 - Updating systems & servers data ...
! 2015.01.09 21:10:26 - Ready
. 2015.01.09 21:10:45 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:10:55 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
! 2015.01.09 21:11:02 - Checking login ...
. 2015.01.09 21:11:12 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:11:20 - Checking login ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:11:22 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:11:30 - Checking login ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:11:32 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:11:47 - Checking login ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:11:49 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:11:57 - Checking login ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:12:06 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:12:07 - Checking login ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:12:24 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:12:24 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:12:24 - Checking login ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:12:42 - Checking login ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:12:59 - Checking login ..., 8° try failed (The operation has timed out)
F 2015.01.09 21:12:59 - Cannot login. (The operation has timed out)
. 2015.01.09 21:13:29 - Updating systems & servers data ...
. 2015.01.09 21:13:46 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:13:57 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:14:14 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:14:24 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:14:34 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:14:51 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:15:08 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:15:26 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:15:26 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:16:31 - Updating systems & servers data ...
! 2015.01.09 21:16:45 - Checking login ...
. 2015.01.09 21:16:48 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:16:58 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:17:02 - Checking login ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:17:12 - Checking login ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:17:16 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:17:26 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:17:30 - Checking login ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:17:36 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:17:40 - Checking login ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:17:50 - Checking login ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:17:53 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:18:07 - Checking login ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:18:10 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:18:24 - Checking login ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:18:27 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:18:27 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:18:42 - Checking login ..., 8° try failed (The operation has timed out)
F 2015.01.09 21:18:42 - Cannot login. (The operation has timed out)
. 2015.01.09 21:19:33 - Updating systems & servers data ...
. 2015.01.09 21:19:50 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:20:00 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:20:18 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
! 2015.01.09 21:20:21 - Checking login ...
. 2015.01.09 21:20:28 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:20:38 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:20:39 - Checking login ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:20:49 - Checking login ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:20:55 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:21:06 - Checking login ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:21:12 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:21:16 - Checking login ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:21:26 - Checking login ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:21:29 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:21:29 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:21:43 - Checking login ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:22:00 - Checking login ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:22:18 - Checking login ..., 8° try failed (The operation has timed out)
F 2015.01.09 21:22:18 - Cannot login. (The operation has timed out)
. 2015.01.09 21:22:35 - Updating systems & servers data ...
. 2015.01.09 21:47:38 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:47:48 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:48:05 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:48:15 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:48:25 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:48:43 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:49:00 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:49:17 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:49:17 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:50:23 - Updating systems & servers data ...
. 2015.01.09 21:50:40 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:50:50 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:51:07 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:51:17 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:51:27 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:51:45 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:52:02 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:52:19 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:52:19 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:53:25 - Updating systems & servers data ...
. 2015.01.09 21:53:42 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:53:52 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:54:09 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:54:19 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:54:29 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:54:46 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:55:06 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
! 2015.01.09 21:55:07 - Checking login ...
. 2015.01.09 21:55:23 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.09 21:55:23 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.09 21:55:24 - Checking login ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:55:34 - Checking login ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:55:51 - Checking login ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:56:01 - Checking login ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:56:11 - Checking login ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:56:28 - Checking login ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:56:29 - Updating systems & servers data ...
. 2015.01.09 21:56:46 - Checking login ..., 7° try failed (The operation has timed out)
. 2015.01.09 21:56:46 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.09 21:56:56 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.09 21:57:03 - Checking login ..., 8° try failed (The operation has timed out)
F 2015.01.09 21:57:03 - Cannot login. (The operation has timed out)
. 2015.01.09 21:57:13 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.09 21:57:23 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.09 21:57:33 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.09 21:57:51 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.09 21:58:08 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
