Not connected, Your IP: 3.17.174.239
chewy74
ANSWERED Auto start and connect after reboot on raspberry pi
I'm trying to automatically connect to airvpn server Cephei if I reboot raspberry pi.
I've got the configuration file and renamed to ***.conf and placed it in /etc/openvpn/ folder. From what I've read it should pick up the conf file at startup and connect, but it doesn't.
Am I missing a step? I've read different variations on how to setup...
Running Raspbian on my pi
Thanks for the help
For the noobs
You download the configuration file for your preferred server and then rename the file extension from *ovpn to *conf and move it to /etc/openvpn/
Then
sudo nano /etc/default/openvpn
Look for
#AUTOSTART="servername"
Uncomment to look like
Replace "servername" with whatever server configuration file you generated mines is "AirVPN_Cephei"
Leave out the .conf
Ctrl X and save changes. Now it should connect to your server after rebooting.
Hope this helps someone
For the noobs
Then
Look for
Leave out the .conf
I spent a couple nights trying to find this solution! I was about to give up and was lucky enough to stumble across this post, making it SO SIMPLE!!! I signed up for an account just to say THANK YOU!!
