soulina22
AirVPN does not remember your settings
AirVpn does not remember the settings in the client (windows) and it does not remember your login details either, when windows is starting up...really annoyed when i want it to logon airvpn automatic
is there a fix this? iam new customer, dont know if this is a general problem with the client
please make sure that in the client window to log in the service (the "Overview" tab), "Remember" is ticked before you enter your credentials.
it is ticked - when iam logging in, but as soon iam restarting my pc and windows is starting up, do i have the same problem again - login details is not remembered along with my settings in the client
we're unable to reproduce the issue, can you provide more information: Eddie version, Windows version, Eddie log?
I also have this problem, on my laptop. My desktop works fine though.
Laptop is running Xubuntu 14.04 64bits and Eddie version is 2.4. However, it also had this problem on Eddie 2.3.
I've added the logs in attachment. Please let me know if, for some reason, you can't see it.
AirVPN_20140827_080942.txt
Windows 8.1 64 bit,  AirVPN Client: Eddie 2.4
Client Logs:
  2014.08.27 07:44:28 - AirVPN client version: 2.4, System: Windows, Architecture: x64
. 2014.08.27 07:44:28 - Reading options from C:\Program Files\AirVPN\AirVPN.xml
. 2014.08.27 07:44:28 - Profile options not found, using defaults.
. 2014.08.27 07:44:29 - Data Path: C:\Program Files\AirVPN
. 2014.08.27 07:44:29 - App Path: C:\Program Files\AirVPN
. 2014.08.27 07:44:29 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2014.08.27 07:44:29 - Command line arguments:
. 2014.08.27 07:44:29 - Operating System: Microsoft Windows NT 6.2.9200.0
I 2014.08.27 07:44:32 - OpenVPN Driver - TAP-Windows Adapter V9
I 2014.08.27 07:44:32 - OpenVPN - Version: OpenVPN 2.3.4 (C:\Program Files\AirVPN\openvpn.exe)
I 2014.08.27 07:44:32 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2014.08.27 07:44:32 - SSL - Version: stunnel 4.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2014.08.27 07:44:32 - IPV6: Available
! 2014.08.27 07:44:32 - Ready
! 2014.08.27 07:45:05 - Checking login ...
! 2014.08.27 07:45:06 - Logged in.
I 2014.08.27 07:45:19 - Session starting.
! 2014.08.27 07:45:19 - Checking environment
! 2014.08.27 07:45:20 - Checking authorization
! 2014.08.27 07:45:21 - Connecting to Erakis (Netherlands, Amsterdam)
. 2014.08.27 07:45:21 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 18 2014
. 2014.08.27 07:45:21 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.08.27 07:45:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.08.27 07:45:21 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.08.27 07:45:21 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 07:45:21 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 07:45:21 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2014.08.27 07:45:21 - OpenVPN > UDPv4 link local: [undef]
. 2014.08.27 07:45:21 - OpenVPN > UDPv4 link remote: [AF_INET]62.212.72.162:443
. 2014.08.27 07:45:22 - OpenVPN > TLS: Initial packet from [AF_INET]62.212.72.162:443, sid=19f61def 272407fd
. 2014.08.27 07:45:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.27 07:45:24 - OpenVPN > Validating certificate key usage
. 2014.08.27 07:45:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.27 07:45:24 - OpenVPN > VERIFY KU OK
. 2014.08.27 07:45:24 - OpenVPN > Validating certificate extended key usage
. 2014.08.27 07:45:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.27 07:45:24 - OpenVPN > VERIFY EKU OK
. 2014.08.27 07:45:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.27 07:45:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 07:45:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 07:45:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 07:45:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 07:45:31 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.08.27 07:45:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.212.72.162:443
. 2014.08.27 07:45:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.08.27 07:45:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.102.238 10.4.102.237'
. 2014.08.27 07:45:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.08.27 07:45:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.08.27 07:45:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.08.27 07:45:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.08.27 07:45:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.08.27 07:45:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.08.27 07:45:33 - OpenVPN > open_tun, tt->ipv6=0
. 2014.08.27 07:45:33 - OpenVPN > TAP-WIN32 device [LAN-forbindelse] opened: \\.\Global\{2EC49354-A41C-4026-81BD-0259AFC6A537}.tap
. 2014.08.27 07:45:33 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.08.27 07:45:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.102.238/255.255.255.252 on interface {2EC49354-A41C-4026-81BD-0259AFC6A537} [DHCP-serv: 10.4.102.237, lease-time: 31536000]
. 2014.08.27 07:45:33 - OpenVPN > Successful ARP Flush on interface [8] {2EC49354-A41C-4026-81BD-0259AFC6A537}
. 2014.08.27 07:45:38 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2014.08.27 07:45:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.212.72.162 MASK 255.255.255.255 192.168.0.1
. 2014.08.27 07:45:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2014.08.27 07:45:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2014.08.27 07:45:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.102.237
. 2014.08.27 07:45:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2014.08.27 07:45:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.102.237
. 2014.08.27 07:45:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.102.237
. 2014.08.27 07:45:38 - Starting Management Interface
. 2014.08.27 07:45:38 - OpenVPN > Initialization Sequence Completed
! 2014.08.27 07:45:38 - Flushing DNS
! 2014.08.27 07:45:40 - Checking route
! 2014.08.27 07:45:41 - Connected.
. 2014.08.27 07:45:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2014.08.27 07:45:42 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2014.08.27 08:45:31 - OpenVPN > TLS: soft reset sec=0 bytes=626326974/0 pkts=705896/0
. 2014.08.27 08:45:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.27 08:45:33 - OpenVPN > Validating certificate key usage
. 2014.08.27 08:45:33 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.27 08:45:33 - OpenVPN > VERIFY KU OK
. 2014.08.27 08:45:33 - OpenVPN > Validating certificate extended key usage
. 2014.08.27 08:45:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.27 08:45:33 - OpenVPN > VERIFY EKU OK
. 2014.08.27 08:45:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.27 08:45:41 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 08:45:41 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 08:45:41 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 08:45:41 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 08:45:41 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
I 2014.08.27 09:45:31 - Renewing TLS key
. 2014.08.27 09:45:31 - OpenVPN > TLS: tls_process: killed expiring key
. 2014.08.27 09:45:41 - OpenVPN > TLS: soft reset sec=0 bytes=765687852/0 pkts=833897/0
. 2014.08.27 09:45:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.27 09:45:42 - OpenVPN > Validating certificate key usage
. 2014.08.27 09:45:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.27 09:45:42 - OpenVPN > VERIFY KU OK
. 2014.08.27 09:45:42 - OpenVPN > Validating certificate extended key usage
. 2014.08.27 09:45:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.27 09:45:42 - OpenVPN > VERIFY EKU OK
. 2014.08.27 09:45:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.27 09:45:44 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 09:45:44 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 09:45:44 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 09:45:44 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 09:45:44 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
I 2014.08.27 10:45:41 - Renewing TLS key
. 2014.08.27 10:45:41 - OpenVPN > TLS: tls_process: killed expiring key
. 2014.08.27 10:45:44 - OpenVPN > TLS: soft reset sec=0 bytes=774533867/0 pkts=858414/0
. 2014.08.27 10:45:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.27 10:45:45 - OpenVPN > Validating certificate key usage
. 2014.08.27 10:45:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.27 10:45:45 - OpenVPN > VERIFY KU OK
. 2014.08.27 10:45:45 - OpenVPN > Validating certificate extended key usage
. 2014.08.27 10:45:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.27 10:45:45 - OpenVPN > VERIFY EKU OK
. 2014.08.27 10:45:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.27 10:45:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 10:45:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 10:45:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.27 10:45:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.27 10:45:47 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Had the same issue.
Just tick a box you like for your settings/credentials. Then Save.
Exit the client. Start client again.
Check your ticked box settings/credentials.
If all-right, then exit the client. (click disconnect)
Shutdown your device.
Restart device.......
Start client, check.
Side-note. its important that you close your client yourself not your system shutdown.
Worked for me in this order.
@highspeedme I didn't try what you wrote, not religiously atleast. I did restart several times and check/unchecked the "remember me" box..
I've fixed the problem by uninstalling Eddie and installing it again.
Hi, I signed up recently and I'm also having this problem.  I'm on Windows 8.1, same problem even after  a clean windows recovery.  Save tickbox is ticked.  Tried exiting the client, restarted it and the settings, even logon creds were not saved.
We resolved an issue of the AirVPN Client, about the Windows Autostart option that doesn't load the correct preferences.
The issue affected only Windows users, and only those who had chosen the Installer version and not the Portable version. For that, we decided to only patch the current 2.7 release.
Please re-download and re-install, enter Preferences and exit at least one time to resolve the issue.
I've just installed the Windows client yesterday. I'm still having the exact same problem. Only happens on computer restart though, but everytime all settings are reset and "remembered" passwords forgotton...
I had problems of AirVPN's client not saving my settings on every PC I've tried. No idea how staff "can't reproduce the issue", perhaps they haven't tried hard enough... Anyway, something that worked for me was TICK THE BOX BEFORE FILLING IN THE INFO.
Whoever is having this problem, please try clicking on the "remember me" option before writing your details. Let us know if that worked for you.
