whodinni570 0 Posted ... Issues with connection. I have been able to connect previously but am now blocked from access. I am on a mac OSX with Lion. When I try to connect through the tunnelblick icon it indicates "The credentials (passphrase or username/password) were not accepted by the remote VPN server". I go to your AirVPN website and log in but it says I'm not connected. How do I authenticate my account and get connected??? I have 3 configurations that have all previously worked and now none of them do. I went through and created another configuration, this time a private one, to see if it would work but still nothing. It asks for my passphrase to create a shadow version but then indicates that it cannot do so and refers me to the log which reads this.... "2011-12-19 13:28:32 *Tunnelblick: OS X 10.7.2; Tunnelblick 3.2beta36 (build 2871)" Thanks for your time Quote Share this post Link to post
Staff 9751 Posted ... whodinni570 wrote:Issues with connection.I have been able to connect previously but am now blocked from access. I am on a mac OSX with Lion. When I try to connect through the tunnelblick icon it indicates "The credentials (passphrase or username/password) were not accepted by the remote VPN server". I go to your AirVPN website and log in but it says I'm not connected. How do I authenticate my account and get connected??? I have 3 configurations that have all previously worked and now none of them do. I went through and created another configuration, this time a private one, to see if it would work but still nothing. It asks for my passphrase to create a shadow version but then indicates that it cannot do so and refers me to the log which reads this.... "2011-12-19 13:28:32 *Tunnelblick: OS X 10.7.2; Tunnelblick 3.2beta36 (build 2871)"Thanks for your timeHello!We can confirm you that your account is on premium status, authorized to access all the servers. There was no change of certificates or configurations recently from our side. Did you change anything in your system Tunnelblick configuration? Could you please send us the connection logs?Kind regards Quote Share this post Link to post
whodinni570 0 Posted ... Hi thanks for your reply. The only thing that I have done recently is to install openVPN on my Iphone so I could access airVPN through it. It worked fine until I tried to access today after I could not access from my main computer. Here is one log: 2011-12-19 16:50:36 *Tunnelblick: OS X 10.7.2; Tunnelblick 3.2beta36 (build 2871) 2011-12-19 16:50:36 *Tunnelblick: Attempting connection with Empty Tunnelblick VPN Configuration; Set nameserver = 1; monitoring connection 2011-12-19 16:50:36 *Tunnelblick: /Applications/Privacy/Tunnelblick.app/Contents/Resources/openvpnstart start Empty\ Tunnelblick\ VPN\ Configuration.tblk 1337 1 0 3 0 49 -atDASNGWrdasngw 2011-12-19 16:50:36 *Tunnelblick: openvpnstart: /Applications/Privacy/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Shared/Empty Tunnelblick VPN Configuration.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Shared/Empty Tunnelblick VPN Configuration.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-SEmpty Tunnelblick VPN Configuration.tblk-SContents-SResources-Sconfig.ovpn.1_0_3_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Privacy/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Privacy/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart 2011-12-19 16:50:37 *Tunnelblick: openvpnstart message: Loading tun.kext 2011-12-19 16:50:37 *Tunnelblick: Established communication with OpenVPN 2011-12-19 16:50:37 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Nov 10 2011 2011-12-19 16:50:37 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337 2011-12-19 16:50:37 Need hold release from management interface, waiting... 2011-12-19 16:50:37 MANAGEMENT: Client connected from 127.0.0.1:1337 2011-12-19 16:50:37 MANAGEMENT: CMD 'pid' 2011-12-19 16:50:37 MANAGEMENT: CMD 'state on' 2011-12-19 16:50:37 MANAGEMENT: CMD 'state' 2011-12-19 16:50:37 MANAGEMENT: CMD 'hold release' 2011-12-19 16:50:37 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2011-12-19 16:50:37 WARNING: file 'user.key' is group or others accessible 2011-12-19 16:50:37 LZO compression initialized 2011-12-19 16:50:37 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 2011-12-19 16:50:37 Socket Buffers: R=[42080->65536] S=[9216->65536] 2011-12-19 16:50:37 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 2011-12-19 16:50:37 Local Options hash (VER=V4): '22188c5b' 2011-12-19 16:50:37 Expected Remote Options hash (VER=V4): 'a8f55717' 2011-12-19 16:50:37 UDPv4 link local: [undef] 2011-12-19 16:50:37 UDPv4 link remote: 174.140.166.91:443 2011-12-19 16:50:37 MANAGEMENT: >STATE:1324342237,WAIT,,, 2011-12-19 16:50:37 MANAGEMENT: >STATE:1324342237,AUTH,,, 2011-12-19 16:50:37 TLS: Initial packet from 174.140.166.91:443, sid=99c46772 47f8cb38 2011-12-19 16:50:37 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 2011-12-19 16:50:37 VERIFY OK: nsCertType=SERVER 2011-12-19 16:50:37 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 2011-12-19 16:50:38 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2011-12-19 16:50:38 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2011-12-19 16:50:38 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2011-12-19 16:50:38 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2011-12-19 16:50:38 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2011-12-19 16:50:38 [server] Peer Connection Initiated with 174.140.166.91:443 2011-12-19 16:50:40 MANAGEMENT: >STATE:1324342240,GET_CONFIG,,, 2011-12-19 16:50:41 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2011-12-19 16:50:41 AUTH: Received AUTH_FAILED control message 2011-12-19 16:50:41 SIGTERM received, sending exit notification to peer 2011-12-19 16:50:46 *Tunnelblick: Flushed the DNS cache 2011-12-19 16:50:46 event_wait : Interrupted system call (code=4) 2011-12-19 16:50:46 TCP/UDP: Closing socket 2011-12-19 16:50:46 SIGTERM[hard,] received, process exiting 2011-12-19 16:50:46 MANAGEMENT: >STATE:1324342246,EXITING,SIGTERM,, Quote Share this post Link to post
Staff 9751 Posted ... Hello! Ok, problem detected from the logs. You are trying to connect to Sigma server, which is currently not publicly available. We apologize for the inconvenience and we are going to put a warning in the forum right now. For the USA servers, try the connection to Sirius (1 Gbit/s dedicated port server, Virginia) or Vega (1 Gbit/s, Oregon), you should have better performance (Sigma is on a 100 Mbit/s switch). Go to the "Member"->"Access without our client" and generate a new configuration for Sirius or Vega. Let us know if everything is all right. Kind regards Quote Share this post Link to post
whodinni570 0 Posted ... Issue resolved! Thank you. Also, I'm very new to all of this and don't know the significance of the port #'s and the TCP information. Should I be aware of anything? Another question.... how do I create a private configuration? I have attempted a few times with no luck. Thanks again for all your help! Quote Share this post Link to post
Staff 9751 Posted ... whodinni570 wrote:Issue resolved!Thank you.Also, I'm very new to all of this and don't know the significance of the port #'s and the TCP information. Should I be aware of anything?Hello!We're glad to know that the issue has been resolved. We apologize for the inconvenience.About ports significance and TCP - UDP connection difference, please refer to the FAQ available here:https://airvpn.org/index.php?option=com_content&view=article&id=71&Itemid=137 (see "What is the difference between TCP and UDP ports? Which port should I choose?").Another question.... how do I create a private configuration? I have attempted a few times with no luck.According to the Tunneblick wiki, "private configurations are stored in '~/Library/Application Support/Tunnelblick Configurations'. Since these files are all located in the user's Library folder, they must be set up separately for each user. (Note that the "~" in the path indicates the user's home folder; thus the folder is actually located somewhere such as /Users/username/Library/Application Support/Tunnelblick/Configurations. Do not confuse this Library folder with the /Library folder located at the root of the filesystem.) Shared configurations, which can only be Tunnelblick VPN Connection files, are stored in /Library/Application Support/Tunnelblick/Shared. Shared configurations do not need to be set up for each user. (In fact, that's the whole point of sharing them!)" See also http://code.google.com/p/tunnelblick/wiki/cFileLocationsThanks again for all your help! You're welcome! Please do not hesitate to contact us for any further information.Kind regards Quote Share this post Link to post
