Not connected, Your IP: 3.146.35.203
Wolf666
Dedicated virtual (wireless) AP bypassing VPN
I am succesfully connected to airvpn via my Netgear R7000, running DD-WRT r24710M.
All my LAN devices (Wired and Wireless) connects Internet via VPN.
I am pretty satisfied and I will buy a 1 year subscription for sure.
Here the firewall settings:
iptables -I FORWARD -i br0 -o tun1 -j ACCEPT
iptables -I FORWARD -i tun1 -o br0 -j ACCEPT
iptables -I INPUT -i tun1 -j REJECT
iptables -t nat -A POSTROUTING -o tun1 -j MASQUERADE
I also set up all the port forwardings, really easy and effective.
Now I would like to setup another Wireless AP, with interface wl0.1, assigning it to a new bridge "br1" staying in a different subnet than "br0". I will also setup a second DHCP. I successfully created that, it works but the traffic is forced to VPN.
Looking at the client dialog box, I see this messages:
0140729 19:25:55 I [server] Peer Connection Initiated with [AF_INET]95.xxx.xxx.xxx:443
20140729 19:25:58 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
20140729 19:25:58 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 dhcp-option DNS 10.4.0.1 comp-lzo no route 10.4.0.1 topology net30 ping 10 ping-restart 60 ifconfig 10.4.xxx.xxx 10.4.xxx.xxx'
20140729 19:25:58 OPTIONS IMPORT: timers and/or timeouts modified
20140729 19:25:58 NOTE: --mute triggered...
Does it mean I cannot be able to avoid VPN with setting a new interface, since the Server pushes the redirect-gateway command?
Thanks for help, I am pretty noob with VPN.
- Router/Firewall pfSense 23.01 (11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz)
- Switch Cisco SG350-10
- AP Netgear RAX200 (Stock FW)
- NAS Synology DS1621+ (5 x 5TB WD Red)
- ISP: Fiber 1000/300 (PPPoE)
