torrent problem UDP block?
  • Please log in to reply
24 replies to this topic
#1 freeworld
freeworld
    Member
  • Members
  • PipPip
  • 24 posts
Posted 29 July 2014 - 12:14 AM
I havent been able to DL any torrents that have UDP trackers/connections.  did airvpn block all UDP traffic?
#2 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7797 posts
Posted 29 July 2014 - 12:22 AM
No, we don't block UDP, we do not discriminate protocols or applications and we do not monitor traffic.
#3 freeworld
freeworld
    Member
  • Members
  • PipPip
  • 24 posts
Posted 29 July 2014 - 12:25 AM
Thx for quick reply.  Anybody have any suggestions?  No torrents work in utorrent that are connecting to UDP trackers i've tried over 30 different torrents all the trackers say time out.
Also, they all work when i am not connected to airvpn.
#4 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7797 posts
Posted 29 July 2014 - 12:31 AM
Which VPN servers do you experience the problem on? And which trackers?
#5 freeworld
freeworld
    Member
  • Members
  • PipPip
  • 24 posts
Posted 29 July 2014 - 12:51 AM
Kuma, electra, Librae, sirius,  I also just went through and hit 2 candian servers Dhneb same problem but they started working immediately on Cephei.
I double checked by going back to kuma and librae and wouldnt work on those servers again back to Cephei and they started right up.
I tried torrents with magnet links and actual torrent files
they all come back with connection timed out.
open.demonii.com
tracker.istole.it
tracker.openbittorrent.com
tracker.publicbt.com
exodus.1337x.org/announce
10.rarbg.com
tracker.ccc.de
#6 giganerd
giganerd
    I shall have no title
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 29 July 2014 - 09:04 AM
open.demonii.com
tracker.istole.it
10.rarbg.com
tracker.ccc.de
These trackers are called public and they are known for blocking proxies/VPN providers.
Always remember:
There's a guide to AirVPN,
Amazon IPs are not dangerous here,
running TOR exits is discouraged,
using spoilers for your logs helps us read your thread.
~ Furthermore, I propose that your paranoia is to be destroyed. ~
Instead of writing me a personal mail, consider contacting me via XMPP at gigan3rd@xmpp.airvpn.org or join the lounge@conference.xmpp.airvpn.org. I might read the mail too late whereas I'm always available on XMPP ;)
#7 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7797 posts
Posted 29 July 2014 - 10:16 AM
Yes, what gigan3rd writes is correct. Some trackers administrators block entire datacenters in an attempt to mitigate trolling from copyright trolls. Nowadays trackers have become a burden and a problem under this aspect, they are perfect for copyright trolls and IP harvesting.
Please use DHT and PEX which make trackers useless.
#8 freeworld
freeworld
    Member
  • Members
  • PipPip
  • 24 posts
Posted 31 July 2014 - 08:04 PM
Well, I have DHT and Pex neither of which work.  There seems to be some sort of worldwide block on airvpn servers, i spent 2hr this morning going through over dozen airvpn servers and none anywhere worked with any torrent.
As a last ditch effort does anybody have any suggestions for me?  I love airvpn, however this issue means i will not be renewing my sub and will be lookin at alternate vpn providers.  While this issue is probably also a problem at other providers a couple have told me they rotate their server IPs so that there are always some servers that are not blocked.
#9 SlyFox
SlyFox
    Advanced Member
  • Members
  • PipPipPip
  • 86 posts
Posted 31 July 2014 - 09:43 PM
One thought: Maybe once a month I have an issue with my torrent client, Utorrent. I just change the port the torrent client is using in Utorrent settings and its back to working.
#10 freeworld
freeworld
    Member
  • Members
  • PipPip
  • 24 posts
Posted 31 July 2014 - 10:29 PM
i did try another port, but thing is it works immediatly w/o problem when not connected to airvpn servers, so i dont know wut to do.
#11 ZPKZ
ZPKZ
    Advanced Member
  • Members2
  • PipPipPip
  • 357 posts
Posted 01 August 2014 - 02:32 PM
I found that some of the dutch servers work perfectly for torrenting for me, while some don't.
Currently connected to Nekkar (NL) and this one works for me. Try it out!
#12 giganerd
giganerd
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 01 August 2014 - 03:41 PM
DHT/LPD/PEX work good for me on all german servers. My tracker, too.
(Sent via Tapatalk 4)
Always remember:
#13 scottfern
scottfern
  • Members
  • Pip
  • 1 posts
Posted 07 August 2014 - 06:03 PM
I am having a similar issue with trackers not connecting using any USA server.  Off VPN and using European servers I am able to connect to trackers.  Was there a change in policy no longer allowing bit torrent protocol on USA servers?
#14 qaywsx
qaywsx
  • Members
  • Pip
  • 1 posts
Posted 22 August 2014 - 10:49 AM
I had the same problem for many days, tried different server - trackers still "can't connect"
Today I updated my torrent-client (transmission @ raspberry pi) to version 2.82 -> everything works like charm, amazing DL-Speeds.
Maybe the trackers block old(er) clients?
#15 dakon720
dakon720
  • Members
  • Pip
  • 1 posts
Posted 01 September 2014 - 09:39 PM
Some older versions of clients don"t have UDP support  (ie: uTorrent didn't add it  until version 2.0.0). Nowadays it's more unlikely, but still possible.
#16 splatter
splatter
  • Members
  • Pip
  • 2 posts
Posted 06 November 2014 - 12:40 AM
I am also having the same issue using US servers. I can connect fine to trackers when not using the VPN, and when in vpn I can 'nc -vv -zu tracker.openbittorrent.com 80' and connect fine, but no love through any airvpn server.
Admin: This isn't on the tracker side because I can connect using the command line while connected to the VPN. DHT and PEX are useless except for a few torrents and only even then I can only get a handfull of peers, suggesting them is not a fix for airvpn network issues.
#17 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7797 posts
Posted 06 November 2014 - 03:09 AM
@splatter
DHT is a complete replacement for trackers and it is of course to be strongly preferred over trackers because it solves one the major problems of bittorrent (centralization due to trackers). We don't know why you find issues with DHT, try to boost peer discovery with PEX.
On which VPN servers do you experience the problem you report?
#18 NickRiviera118
NickRiviera118
  • Members
  • Pip
  • 1 posts
Posted 06 November 2014 - 09:29 PM
I have the same problem. My utorrent client cannot seem to connect with any trackers. I'm using NL server ACRUX.
DHT and PEX works fine, but i'm struggling to find the right torrents for this method.
#19 the100thmonkey
the100thmonkey
    Member
  • Members
  • PipPip
  • 11 posts
Posted 10 November 2014 - 03:31 PM
Same here:
openbittorrent
istole.it
publicbt
demonii
All are blocked on Antares (Singapore). istole.it and Demonii worked fine until about a week ago.
DHT and PEX do work, albeit slowly and for well-seeded torrents, but I find that they tend not to work when DLing torrents with few seeds.
#20 htpc
htpc
    Advanced Member
  • Members2
  • PipPipPip
  • 75 posts
Posted 27 November 2014 - 01:44 PM
I have to put myself on the list as well - was on vacation for a few days and since my return no luck with torrent downloading (openbittorrent, istole.it, publicbt, demonii) on multiple US servers. Was working perfectly before. I have to specify though downloads do start at one - after a long wait - point in Transmission with DHT and PEX but not so on my Mediacenter which has a built in torrent client where I don't have controll over DHT and PEX.
Is there anything we can do to get this working again?
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 15115 - BW: 47083 Mbit/sYour IP: 34.229.194.198Guest Access.
