Speedtest showing real location and not VPNs
  • Please log in to reply
3 replies to this topic
#1 refresh
refresh
    Advanced Member
  • Members
  • PipPipPip
  • 163 posts
Posted 20 July 2014 - 11:10 AM
Bit of a strange one I know speedtest seems inaccurate but before it was showing my VPN connected location ie the country I was connected to but all of a sudden past few days it is now showing my real location in my own country.
ipleak and grc test confirm the IP and location is that of the VPN country, so why has speedtest suddenly figured out my real location ?
Any ideas?
#2 go558a83nk
go558a83nk
    Advanced Member
  • Members2
  • PipPipPip
  • 1705 posts
Posted 20 July 2014 - 04:32 PM
web browsers may leak your location directly.  I know firefox has a switch to turn it off.  about:config, geo.enabled, set to false.
not sure how to edit this function in other browsers.
#3 44blablabla
44blablabla
  • Members
  • Pip
  • 6 posts
Posted 20 July 2014 - 05:24 PM
Which browser and OS do you use? Is geolocation off (in FF search for geo in about:config)? Did you make sure that your only used nameserver is 10.4.0.1? How exact is your real location detected? If it's only your country, the website might use your browsers prefered language setting sent in every request.
#4 refresh
refresh
    Advanced Member
  • Members
  • PipPipPip
  • 163 posts
Posted 20 July 2014 - 11:39 PM
geo.enabled set to off in about config
and tried other browsers just in case...
10.4.0.1 listed under my pfsense which is working fine as far as I can tell ill reset my firewall just in case but yeah pretty strange that speedtest reports my location but list the vpn ip as in another country. Even ipleak shows the correct geo location of the vpn exit.
thanks for suggestions bit of a strange one indeed!
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 16153 - BW: 61767 Mbit/sYour IP: 3.91.79.74Guest Access.
