mage1982 15 Posted ... In a session that has been up for a while (days), I suddenly see some unexpected things in the log output from OpenVPN. I noticed some ongoing HTTP connections going over the VPN also shut down unexpectedly. Someone at AirVPN messing about with the server or something else? Sorry for vomiting up pages of logs, I'll point out the interesting lines below. Thu Jul 17 06:16:08 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, 0=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 06:16:24 2014 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyThu Jul 17 06:16:24 2014 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationThu Jul 17 06:16:24 2014 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyThu Jul 17 06:16:24 2014 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationThu Jul 17 06:16:24 2014 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSAThu Jul 17 07:16:08 2014 TLS: tls_process: killed expiring keyThu Jul 17 07:16:24 2014 TLS: soft reset sec=0 bytes=333383635/0 pkts=391961/0Thu Jul 17 07:16:24 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.orgThu Jul 17 07:16:24 2014 Validating certificate key usageThu Jul 17 07:16:24 2014 ++ Certificate has key usage 00a0, expects 00a0Thu Jul 17 07:16:24 2014 VERIFY KU OKThu Jul 17 07:16:24 2014 Validating certificate extended key usageThu Jul 17 07:16:24 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server AuthenticationThu Jul 17 07:16:24 2014 VERIFY EKU OKThu Jul 17 07:16:24 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:18:06 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:18:06 2014 TLS Error: TLS handshake failedThu Jul 17 07:18:06 2014 TLS: move_session: dest=TM_LAME_DUCK src=TM_ACTIVE reinit_src=1Thu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS: Initial packet from [AF_INET]62.212.72.175:443, sid=01d68ee5 1e093b39Thu Jul 17 07:18:10 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.orgThu Jul 17 07:18:10 2014 Validating certificate key usageThu Jul 17 07:18:10 2014 ++ Certificate has key usage 00a0, expects 00a0Thu Jul 17 07:18:10 2014 VERIFY KU OKThu Jul 17 07:18:10 2014 Validating certificate extended key usageThu Jul 17 07:18:10 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server AuthenticationThu Jul 17 07:18:10 2014 VERIFY EKU OKThu Jul 17 07:18:10 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:19:01 2014 TLS: new session incoming connection from [AF_INET]62.212.72.175:443Thu Jul 17 07:19:03 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.orgThu Jul 17 07:19:03 2014 Validating certificate key usageThu Jul 17 07:19:03 2014 ++ Certificate has key usage 00a0, expects 00a0Thu Jul 17 07:19:03 2014 VERIFY KU OKThu Jul 17 07:19:03 2014 Validating certificate extended key usageThu Jul 17 07:19:03 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server AuthenticationThu Jul 17 07:19:03 2014 VERIFY EKU OKThu Jul 17 07:19:03 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:19:38 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:19:38 2014 TLS Error: TLS handshake failedThu Jul 17 07:19:38 2014 TLS: Initial packet from [AF_INET]62.212.72.175:443, sid=7badb579 e57e0569Thu Jul 17 07:19:40 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.orgThu Jul 17 07:19:40 2014 Validating certificate key usageThu Jul 17 07:19:40 2014 ++ Certificate has key usage 00a0, expects 00a0Thu Jul 17 07:19:40 2014 VERIFY KU OKThu Jul 17 07:19:40 2014 Validating certificate extended key usageThu Jul 17 07:19:40 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server AuthenticationThu Jul 17 07:19:40 2014 VERIFY EKU OKThu Jul 17 07:19:40 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:20:18 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:20:18 2014 TLS Error: TLS handshake failedThu Jul 17 07:20:18 2014 TLS: new session incoming connection from [AF_INET]62.212.72.175:443Thu Jul 17 07:20:20 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.orgThu Jul 17 07:20:20 2014 Validating certificate key usageThu Jul 17 07:20:20 2014 ++ Certificate has key usage 00a0, expects 00a0Thu Jul 17 07:20:20 2014 VERIFY KU OKThu Jul 17 07:20:20 2014 Validating certificate extended key usageThu Jul 17 07:20:20 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server AuthenticationThu Jul 17 07:20:20 2014 VERIFY EKU OKThu Jul 17 07:20:20 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:20:58 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:20:58 2014 TLS Error: TLS handshake failedThu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS: Initial packet from [AF_INET]62.212.72.175:443, sid=21a8c3fb 50eadad4Thu Jul 17 07:20:59 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.orgThu Jul 17 07:20:59 2014 Validating certificate key usageThu Jul 17 07:20:59 2014 ++ Certificate has key usage 00a0, expects 00a0Thu Jul 17 07:20:59 2014 VERIFY KU OKThu Jul 17 07:20:59 2014 Validating certificate extended key usageThu Jul 17 07:20:59 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server AuthenticationThu Jul 17 07:20:59 2014 VERIFY EKU OKThu Jul 17 07:20:59 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:21:08 2014 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyThu Jul 17 07:21:08 2014 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationThu Jul 17 07:21:08 2014 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit keyThu Jul 17 07:21:08 2014 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authenticationThu Jul 17 07:21:08 2014 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSAThu Jul 17 07:21:18 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:21:18 2014 TLS Error: TLS handshake failed Ok, now the blow-by-blow version. So first we have an existing connection, and at 7:16 the usual key renegotiation occurs. Certificate validates OK, but then "TLS key negotiation failed to occur". (And what's this business with "move_session"? Just state keeping on the server?) Thu Jul 17 07:16:24 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.orgThu Jul 17 07:18:06 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:18:06 2014 TLS Error: TLS handshake failedThu Jul 17 07:18:06 2014 TLS: move_session: dest=TM_LAME_DUCK src=TM_ACTIVE reinit_src=1Thu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS ERROR: received control packet with stale session-id=a2c377d7 6ea5974cThu Jul 17 07:18:07 2014 TLS: Initial packet from [AF_INET]62.212.72.175:443, sid=01d68ee5 1e093b39Thu Jul 17 07:18:10 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org ..and then it seems to shake loose and continue. Then this, right after: Thu Jul 17 07:19:01 2014 TLS: new session incoming connection from [AF_INET]62.212.72.175:443Thu Jul 17 07:19:03 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org Huh? The Air server is initiating a connection? Certificate validates OK, again, then some further errors: Thu Jul 17 07:20:58 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:20:58 2014 TLS Error: TLS handshake failedThu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1)Thu Jul 17 07:20:58 2014 TLS Error: Unroutable control packet received from [AF_INET]62.212.72.175:443 (si=3 op=P_ACK_V1) Followed by a normal "initial packet" and the usual handshake. Thu Jul 17 07:20:58 2014 TLS: Initial packet from [AF_INET]62.212.72.175:443, sid=21a8c3fb 50eadad4 [handshake] Thu Jul 17 07:21:18 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Thu Jul 17 07:21:18 2014 TLS Error: TLS handshake failed Then more errors. But the connection is still up! What's going on, is something here attempting to set up two connections simultaneously? That could explain the "unroutable" errors. But how come my connection is still going when I see "handshake failed"? I have not touched anything while this was happening. Using OpenVPN 2.3.0. Quote Share this post Link to post
OpenSourcerer 1360 Posted ... I'm connected to the server in question right now. My logs are clean.Are you able to update OpenVPN? Current version is 2.3.4. If you are using Windows, replacing openvpn.exe in the bin folder of your client is enough. Here's the exe file. Report, please. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
mage1982 15 Posted ... If you are using Windows, replacing openvpn.exeWindows? Don't insult me. :-) Are you saying something changed between 2.3.0 and 2.3.4 that could explain this? (2.3.2 seems to be the latest version that is currently available to me, for what it's worth.) Quote Share this post Link to post
OpenSourcerer 1360 Posted ... I don't know about relevant changes, but updating software often saved me from more frustration in the past. Since I'm able to connect using my client on Windows, it is not an error on AirVPN's site. If you are using Windows, replacing openvpn.exeWindows? Don't insult me. :-)I don't, I'm using Windows myself. (Sent via Tapatalk 4) Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
mage1982 15 Posted ... Since I'm able to connect using my client on Windows, it is not an error on AirVPN's site.To be clear, it is definitely not an error - OpenVPN never stopped working, and in fact has kept going through the incident and after - but rather the issue are the strange things in the log that probably shouldn't be there. So as I see it, either Air was doing something out of the ordinary that was confusing OpenVPN (which could be something as trivial as restarting a server process, say), or something or someone else is doing something weird. And in that case I'd like to know. I do appreciate the fact that you are trying to help. Unfortunately there's just nothing here to really fix, as such. Quote Share this post Link to post
OpenSourcerer 1360 Posted ... So as I see it, either Air was doing something out of the ordinary that was confusing OpenVPN (which could be something as trivial as restarting a server process, say), or something or someone else is doing something weird. And in that case I'd like to know So, the issue is gone now? Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
mage1982 15 Posted ... The issue is still unsolved. The mystery double connection hasn't shown up in the logs again since I first posted, if that's what you mean. Can I just reiterate, in case anyone from Air is keeping an eye on the forums, that I'd really like to know if there's anything you can say? I realize it's hard to know what's going on when you don't keep logs, but if this is something that's come up before or if it could be related to something else it would be useful to know. Even just "we don't know". Quote Share this post Link to post
Staff 9760 Posted ... Hello mage1982, we do not detect any problem neither on our side nor on your side. The problem in your logs does not look worrying, it looks like just a temporary line problem. Kind regards Quote Share this post Link to post
