DersuUzala 0 Posted ... Hi, I installed the Eddie client from the .deb package, but when I try to connect I get the error Driver Installation Failed The logs show an error when I installed the client which says: OpenVPN Driver - Not available however, `open-vpn` and `bridge-utils` are installed. Any suggestions to get it working? Quote Share this post Link to post
Staff 9755 Posted ... Hello! We're sorry, this is a known bug of Eddie. It will be fixed soon in the next release. Kind regards Quote Share this post Link to post
ionik 0 Posted ... Hi, Maybe the very next release?A hotfix would also be appreciated.Btw. using Debian 8.4. . 2016.04.30 17:24:21 - App Path: /usr/lib/AirVPN. 2016.04.30 17:24:21 - Executable Path: /usr/lib/AirVPN/AirVPN.exe. 2016.04.30 17:24:21 - Command line arguments (2): path="/root/.airvpn" cli="True". 2016.04.30 17:24:21 - Updating systems & servers data .... 2016.04.30 17:24:21 - Operating System: Unix 3.16.0.4 - Linux gastnetz 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) x86_64 GNU/LinuxE 2016.04.30 17:24:21 - OpenVPN Driver - Not availableI 2016.04.30 17:24:21 - OpenVPN - Version: OpenVPN 2.3.4 (/usr/sbin/openvpn)I 2016.04.30 17:24:21 - SSH - Version: OpenSSH_6.7p1 Debian-5+deb8u2, OpenSSL 1.0.1k 8 Jan 2015 (/usr/bin/ssh)I 2016.04.30 17:24:21 - SSL - Version: stunnel 5.06 (/usr/bin/stunnel4)! 2016.04.30 17:24:21 - Activation of Network Lock - Linux IPTables. 2016.04.30 17:24:21 - Systems & servers data update completedI 2016.04.30 17:24:25 - Checking login ...! 2016.04.30 17:24:25 - Logged in.I 2016.04.30 17:24:25 - Session starting.W 2016.04.30 17:24:26 - Unable to understand if IPV6 is active.F 2016.04.30 17:24:26 - Driver can't be installed. ionik Quote Share this post Link to post
