Not connected, Your IP: 18.191.171.20
jsmith05954
Another connect issue
Please help
6/17/2014 - 7:21 AM AirVPN client version: 1.92
6/17/2014 - 7:21 AM Reading options from C:\Users\MauriceB\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
6/17/2014 - 7:21 AM OpenVPN bundle version: OpenVPN 2.3.2.1396915200
6/17/2014 - 7:21 AM OpenVPN current version: OpenVPN 2.3.2.1396915200
6/17/2014 - 7:21 AM Ready.
6/17/2014 - 7:21 AM Login...
6/17/2014 - 7:21 AM Login success.
6/17/2014 - 7:21 AM Contacting service...
6/17/2014 - 7:21 AM Connecting...
6/17/2014 - 7:21 AM OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Apr  8 2014
6/17/2014 - 7:21 AM Control Channel Authentication: tls-auth using INLINE static key file
6/17/2014 - 7:21 AM Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
6/17/2014 - 7:21 AM Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
6/17/2014 - 7:21 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
6/17/2014 - 7:21 AM UDPv4 link local: [undef]
6/17/2014 - 7:21 AM UDPv4 link remote: [AF_INET]198.203.28.42:443
6/17/2014 - 7:22 AM Disconnecting...
6/17/2014 - 7:22 AM Disconnected.
6/17/2014 - 7:23 AM Login...
6/17/2014 - 7:23 AM Login success.
6/17/2014 - 7:23 AM Contacting service...
6/17/2014 - 7:23 AM Connecting...
6/17/2014 - 7:23 AM OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Apr  8 2014
6/17/2014 - 7:23 AM Control Channel Authentication: tls-auth using INLINE static key file
6/17/2014 - 7:23 AM Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
6/17/2014 - 7:23 AM Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
6/17/2014 - 7:23 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
6/17/2014 - 7:23 AM UDPv4 link local: [undef]
6/17/2014 - 7:23 AM UDPv4 link remote: [AF_INET]198.203.28.42:443
6/17/2014 - 7:24 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
6/17/2014 - 7:24 AM TLS Error: TLS handshake failed
6/17/2014 - 7:24 AM SIGUSR1[soft,tls-error] received, process restarting
6/17/2014 - 7:24 AM Restart pause, 2 second(s)
6/17/2014 - 7:24 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
6/17/2014 - 7:24 AM UDPv4 link local: [undef]
6/17/2014 - 7:24 AM UDPv4 link remote: [AF_INET]198.203.28.42:443
6/17/2014 - 7:24 AM TLS: Initial packet from [AF_INET]198.203.28.42:443, sid=12f8324b bc34851a
6/17/2014 - 7:24 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
6/17/2014 - 7:24 AM Validating certificate key usage
6/17/2014 - 7:24 AM ++ Certificate has key usage  00a0, expects 00a0
6/17/2014 - 7:24 AM VERIFY KU OK
6/17/2014 - 7:24 AM Validating certificate extended key usage
6/17/2014 - 7:24 AM ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
6/17/2014 - 7:24 AM VERIFY EKU OK
6/17/2014 - 7:24 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
6/17/2014 - 7:24 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
6/17/2014 - 7:24 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
6/17/2014 - 7:24 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
6/17/2014 - 7:24 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
6/17/2014 - 7:24 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
6/17/2014 - 7:24 AM [server] Peer Connection Initiated with [AF_INET]198.203.28.42:443
6/17/2014 - 7:24 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
6/17/2014 - 7:24 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.71.170 10.4.71.169'
6/17/2014 - 7:24 AM OPTIONS IMPORT: timers and/or timeouts modified
6/17/2014 - 7:24 AM OPTIONS IMPORT: LZO parms modified
6/17/2014 - 7:24 AM OPTIONS IMPORT: --ifconfig/up options modified
6/17/2014 - 7:24 AM OPTIONS IMPORT: route options modified
6/17/2014 - 7:24 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
6/17/2014 - 7:24 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
6/17/2014 - 7:24 AM open_tun, tt->ipv6=0
6/17/2014 - 7:24 AM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{6EFD13AF-53DA-4B83-8E63-A1C2743776F7}.tap
6/17/2014 - 7:24 AM TAP-Windows Driver Version 9.9
6/17/2014 - 7:24 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.71.170/255.255.255.252 on interface {6EFD13AF-53DA-4B83-8E63-A1C2743776F7} [DHCP-serv: 10.4.71.169, lease-time: 31536000]
6/17/2014 - 7:24 AM Successful ARP Flush on interface [20] {6EFD13AF-53DA-4B83-8E63-A1C2743776F7}
6/17/2014 - 7:24 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe ADD 198.203.28.42 MASK 255.255.255.255 192.168.0.1
6/17/2014 - 7:24 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=100 and dwForwardType=4
6/17/2014 - 7:24 AM Route addition via IPAPI succeeded [adaptive]
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.71.169
6/17/2014 - 7:24 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.71.169
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.71.169
6/17/2014 - 7:24 AM Initialization Sequence Completed
6/17/2014 - 7:24 AM Starting Management Interface...
6/17/2014 - 7:24 AM Checking...
6/17/2014 - 7:24 AM The remote name could not be resolved: 'airvpn.org'
6/17/2014 - 7:24 AM SIGTERM received, sending exit notification to peer
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.71.169
6/17/2014 - 7:24 AM Route deletion via IPAPI succeeded [adaptive]
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe DELETE 198.203.28.42 MASK 255.255.255.255 192.168.0.1
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.71.169
6/17/2014 - 7:24 AM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.71.169
6/17/2014 - 7:24 AM Closing TUN/TAP interface
6/17/2014 - 7:24 AM SIGTERM[hard,] received, process exiting
6/17/2014 - 7:24 AM Disconnected.
