Not connected, Your IP: 3.145.186.6
bluezone
Latency problems in games
I've been experiencing lag spike issues every ~7-10 seconds in games which use UDP (Diablo II, amongst others like TF2)
When i ping a server, such as www.google.ca I tend to experience 60ms but about every 10 seconds it jumps up to unresonable levels (600-700+), Any advice?
I'm connected to a reasonably close server, and using UDP 443 openvpn on ubuntu 14.04
  Hello bluezone,
I suggestion you could try a different ports or do you need port 443 for Gaming?
Also try a different server.
The link below may be helpful have a look.
https://airvpn.org/status/
  Regards,
       Solex1
