Quartz 19 Posted ... What is the best way (if there is a way) to connect to a predefined server by using just one-click? For example, a Windows 8.1 start menu shortcut that once clicked would load up a client and connect to a server. Quote Share this post Link to post
Quartz 19 Posted ... One way I've found so far is to create a openvpn-gui.exe (location below) shortcut, tick 'Run as administrator' in the shortcut's Compatibility tab and specify the --connect ovpn file that can be created from this website's client area->config generator and saved in C:\Program Files\OpenVPN\config. If you're using a 32-bit system use Program Files (x86). "C:\Program Files\OpenVPN\bin\openvpn-gui.exe" --connect Nunki.ovpn Copy the shortcut to your start menu and pin to Start. Job done. 1 OpenSourcerer reacted to this Quote Share this post Link to post
OpenSourcerer 1359 Posted ... Using a self-written script, I think. :: openvpn-script-example.cmd @echo off C:\Path\to\OpenVPN\openvpn.exe AirVPN_config_file.ovpn [antidnsleak-script.cmd] ... ... Something like that. Right click > Pin to start menu and you're done. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
