Vucnu 1 Posted ... Hi,I have just installed stunnel. I have generated the config file using ssl tunnelling. As ssl page I have run the commandstunnel "AirVPN <..> - SSL <..>.ssl" (of course I have launched it with the .ssl file from the generator.I Have this output Clients allowed=500 stunnel 4.53 on x86_64-pc-linux-gnu platform Compiled with OpenSSL 1.0.1e 11 Feb 2013 Running with OpenSSL 1.0.1f 6 Jan 2014 Update OpenSSL shared libraries or rebuild stunnel Threading:PTHREAD SSL:+ENGINE+OCSP Auth:LIBWRAP Sockets:POLL+IPv6 Reading configuration from descriptor 3 Compression not enabled PRNG seeded successfully Initializing inetd mode configuration Section stunnel: SSL server needs a certificate str_stats: 2 block(s), 10 data byte(s), 116 control byte(s) The command openvpn return me TCP: connect to [AF_INET]127.0.0.1:1413 failed, will try again in 5 seconds: Connection refused So, probably the problem are something in stunnel? Please can you help? Thanks Quote Share this post Link to post
Staff 9758 Posted ... Hello! Which server are you connecting stunnel to? From this line:Section stunnel: SSL server needs a certificate it might be a server-side problem. Also, try with "stunnel4" instead of "stunnel" Kind regards Quote Share this post Link to post
Vucnu 1 Posted ... stunnel4 solve the problem, but I have a dns problem. Ping just works but I can't use dns server. Any solution please? Thanks. Quote Share this post Link to post
