Not connected, Your IP: 18.226.150.175
markbutler94
No download speed, worked fine before
I've tried connecting to various servers, but always get the same problem; 0kb/s download, Upload ~34,000kb/s when I'm not even uploading anything. I'm using the AirVPN Client. Obviously nothing will load due to the download rate.
The issue only started today. Any ideas?
Many thanks for your help
Do I need to post logs? If so, how do I go about that?
(Sorry -- think I posted this in the wrong section before)
I'm having the same issue.   Windows 8 RT 32bit with 32bit Airvpn client.
Upload rates maxing out at 22000kbs with 0 download.
Websites or anything for that matter will not load due to the high volume of upload.
Uninstalled-Installed Windows 7 32bit version, same problem.   Brand new Asus T100
Please advise as this is for a friends account on AIRVPN
as far as we know OpenVPN is not available for Windows RT, we're sorry. For any other problem please include the logs.
Good day,
Thanks for your reply on this issue,  understand that Windows 8 RT is not supported,  although, after some tinkering with Eddie 2.2 beta, on windows 8 RT, was receiving constant connect/disconnect loop with windows DNS forced.   Changed UDP to TCP and system connect's without loop and VPN is working.
