Not connected, Your IP: 18.191.186.72
markbutler94
No download speed, very high upload speed (when not uploading)
I've tried connecting to various servers, but always get the same problem; 0kb/s download, Upload ~34,000kb/s when I'm not even uploading anything. Obviously nothing will load due to the download rate.
The issue only started today. Any ideas?
Many thanks for your help
Same problem Win8 64bit. working until yesterday but now nothing
Yes, I'm also running Win 8.1 64 bit.
Have you changed any hardware?
"The issue only started today. Any ideas?"
Did you connect to AirVPN before, without problems?
Yes, worked fine until now. Issue is still persisting,
If you connect with the different protocols, still the same problem?
I've tried using a load of different server locations. I've left the ports as default. Not sure what you mean by different protocols? Sorry, I'm relatively new to this. I use the AirVPN Client though.
