Not connected, Your IP: 3.138.138.144
nikolaos.muilenburg
Using AirVPN with Linux from terminal
I manage to get this far but after Initialization Sequence Completed I cannot browse the web. I have all files in same dir and run command and it seems to connect. However it does not seem that i can surf the web with the vpn
can you wget normally?
try wget a domain, and then wget an ip address, and see how it goes. if its connecting to the ip and not connecting to the domain it means its a dns issue.
