Using AirVPN with OpenVPN for Android
android
  • Please log in to reply
37 replies to this topic
#21 El.Presidente
El.Presidente
  • Members
  • Pip
  • 6 posts
Posted 30 April 2018 - 01:23 PM
Its working on my Cellphone, but when i test it on ipleak.net, the Test said IPv6 is still enabled and the Real IP is unprotected.
#22 zsam288
zsam288
    Advanced Member
  • Members
  • PipPipPip
  • 33 posts
Posted 03 May 2018 - 01:03 PM
Untick 'bypass vpn for local networks' under routing then it will be fine
#23 El.Presidente
El.Presidente
  • Members
  • Pip
  • 6 posts
Posted 10 May 2018 - 10:35 AM
I see your Answer a bit late. :)  I set as you said in my OpenVPN Android App.
Thank you. ;))
#24 AdamKu
AdamKu
  • Members
  • Pip
  • 1 posts
Posted 26 May 2018 - 04:40 PM
simple install just add the file to the SD card  and download from there...
#25 multishare
multishare
  • Members
  • Pip
  • 1 posts
Posted 10 June 2018 - 09:17 PM
Not working ,need certificate to install ???
#26 lopper
lopper
  • Members
  • Pip
  • 1 posts
Posted 25 June 2018 - 03:11 PM
I love this app, it works perfect on my Samsung Galaxy S9
#27 banshee28
banshee28
    Member
  • Members
  • PipPip
  • 14 posts
Posted 29 June 2018 - 02:33 AM
Thanks...I just got this working and also noticed the IP and ISP was not what it should be. Unchecked the "bypass" and it was good. Thanks!
Also, perhaps this should be part of the OP as I would think mostly everyone would want this to show the VPN IP not the original one?
Maybe this is useful for something I am not aware of.....
#28 ableounceony
ableounceony
    Advanced Member
  • Members2
  • PipPipPip
  • 93 posts
Posted 06 July 2018 - 10:41 PM
As of 06 July 2018, the latest version of OpenVPN for Android on the Play Store is 0.7.5.  The information I can find on it says it uses OpenVPN 2.x.  Has anyone found out exactly what that "x" is?  Specifically, can it handle the TLS-crypt configurations here and TLS 1.2 (I believe that's part of 2.4).  I know it has no trouble using GCM cyphers, but I'd like to change my pfSense OpenVPN server to use the following with my Android phones:
- TLS Encryption and Authentication instead of just TLS Authentication under TLS Key Usage Mode, and
- SHA512 instead of SHA1 under Auth Digest Algorithm.
#29 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7755 posts
Posted 07 July 2018 - 12:50 PM
Please check the log, it is probably OpenVPN 2.5.
That said, remember that you can enable OpenVPN 3 Core (check the settings).
This is "tls-crypt" which is supported on about 70 servers of ours (soon on all of them). Remember to connect to entry-IP 3 or 4 to have tls-crypt which is very effective in bypassing some types of blocks, furthermore having the whole Control Channel fully encrypted is cool anyway.
#30 ableounceony
ableounceony
    Advanced Member
  • Members2
  • PipPipPip
  • 93 posts
Posted 07 July 2018 - 03:13 PM
Thanks.  I should have thought of the log.  Yes.  It's OpenVPN 2.5.  I'd also seen the option to use OpenVPN 3 Core, but couldn't find anything about what that meant.  Regardless, it looks like I'll be able to turn on all the cool stuff in my pfSense OpenVPN server and OpenVPN for Android will be able to handle it.
#31 crashstreet
crashstreet
  • Members
  • Pip
  • 2 posts
Posted 18 July 2018 - 06:06 AM
I had this problem too. All the downloads were greyed out and not selectable. I moved the .ovpn files to my SD and could import them from there without issue. Hope that helps
hi,
I have Android 7.1.2 on a Google Pixel XL, and the braniacs at Google designed a phone that does NOT support an SD card. :-(
I cannot move the .ovpn files to an SD card, so Hexane's workaround will not work for me. The .opvn files are thus still stuck in gray limbo.
Can anyone offer a workaround?
Thanks.
#32 crashstreet
crashstreet
  • Members
  • Pip
  • 2 posts
Posted 18 July 2018 - 06:15 AM
hi,
Thanks.
nevermind.
figured out a fix - chose import from phone and manually chose download directory.
Seems to have worked.
Go figure. ;-)
#33 Dna82
Dna82
  • Members
  • Pip
  • 1 posts
Posted 19 July 2018 - 06:33 PM
Well; I have read information related to OpenVPN - AirVPN posted here. I have seamless and successfully Installed Openvpn for Android, but despite having followed directions, steps and variables, IpV6 still leaking IP & Location. Had similar situation on the phone, fixed by using OpevVPN Connect. Sideloaded to the firestick, imported ovpn conf, but not being able to connect. None further steps / options given at the end. Any thoughts? Thanks!
#34 redribbon
redribbon
  • Members
  • Pip
  • 5 posts
Posted 13 August 2018 - 01:47 PM
I've tried openvpn for Android and it works when I use my 4g mobile data. But It doesn't work with the wifi of the hotel where I'm on holliday.
It doesn't work with UDP and neither with Tcp.
I set Linux in airvpn config generator.
Same problems with openvpn Connect and with openvpn client free apps.
The wifi requires a periodically authentication (once a day) on a web page that opens and close automatically when you are authenticated.
A couples of months ago, I used Expressvpn app and It worked with the same wifi network (after the web page authentication) without problems.
Logs:
15:03 OpenVPN 2.5-icsopenvpn [git:v2.4_rc2-301-g14adf04a] armeabi-v7a [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 3 2018
15:03 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10
15:03 TCP/UDP: Preserving recently used remote address: [AF_INET]217.64.127.194:443
15:03 UDP link local: (not bound)
15:03 UDP link remote: [AF_INET]217.64.127.194:443
15:04 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
15:04 TLS Error: TLS handshake failed
15:04 SIGUSR1[soft,tls-error] received, process restarting
Could you help me?
#35 redribbon
redribbon
  • Members
  • Pip
  • 5 posts
Posted 13 August 2018 - 09:17 PM
Just a Little update. I tried also Eddie airvpn beta client and I've got the same problem.
#36 giganerd
giganerd
    I shall have no title
  • Members2
  • PipPipPip
  • 2674 posts
  • LocationGermany
Posted 14 August 2018 - 08:29 PM
Not a problem with OpenVPN for Android, then, is it? :)
Try other ports and protocols first. If it continues, consider opening your own thread so everyone can help you better.
Always remember:
There's a guide to AirVPN,
Amazon IPs are not dangerous here,
running TOR exits is discouraged,
using spoilers for your logs helps us read your thread.
~ Furthermore, I propose that your paranoia is to be destroyed. ~
Instead of writing me a personal mail, consider contacting me via XMPP at gigan3rd@xmpp.airvpn.org or join the lounge@conference.xmpp.airvpn.org. I might read the mail too late whereas I'm always available on XMPP ;)
#37 redribbon
redribbon
  • Members
  • Pip
  • 5 posts
Posted 15 August 2018 - 02:43 PM
I wrote to the Airvpn support. Following what they told me, the problem disappeared with the following
"Advanced Mode" options in the Configuration Generator:
- entry-IP address 3
- port 443
- protocol UDP
So It wasn't an openvpn for Android issue
Thanks to Airvpn support!
#38 iwih2gk
iwih2gk
    Advanced Member
  • Members2
  • PipPipPip
  • 282 posts
Posted 16 August 2018 - 09:12 PM
hi,
Thanks.
Google released Android PIE (9.0) for Pixel XL's.  Your Pixel is two OS's behind.  Mine is running perfectly.  Depending upon "where" you are in the world you might have to download the latest release.  Its just under a Gig, but it loads and runs perfectly.  I know this post is just a bit off "key", but I wanted to inform you or others that the improvements are beyond amazing.  My bad in that it doesn't directly address your concerns.
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
Servers online. Online Sessions: 16098 - BW: 69305 Mbit/sYour IP: 54.205.211.87Guest Access.
