Not connected, Your IP: 18.222.119.148
In the per VPN settings of Tunnelblick, under Advanced -> While Connected, there is a setting called "Route all traffic through the VPN". How important is it to set this option? Does that mean that if not set, there might be DNS or IP leakage?
Thanks.
