Where are client settings and data saved?
  • This topic is locked This topic is locked
No replies to this topic
#1 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7146 posts
Posted 18 March 2014 - 02:43 PM
If the client is installed, by default they are stored in the Application Data of the current user, standard behavior in each operating system. Under Windows:
C:\Users\\AppData\Local\AirVPN
Under Linux:
/home/<username>/.airvpn
If the application is launched standalone (Portable mode), by default it saves data in the same directory of the executable file.
Only if the directory is not writable, it saves data in the user directory as explained above.
You can always control the path with the path options from a command line interface. The value can be a full path, or special values home (for the user directory) or program for the program directory. Examples:
	AirVPN.exe path=C:\mydata
	AirVPN.exe path=home
	AirVPN.exe path=program
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 13336 - BW: 37150 Mbit/sYour IP: 23.20.245.192Guest Access.
