Not connected, Your IP: 3.21.231.245
feelfree
Slow speed on UK servers help
I just installed Airvpn and I tested the speed and I'm getting 2 -3mb download on all the servers I try.
I am on a 60mb line myself this is really bad any help guys.
Bit more details maybe required for anyone to assist you.
What ISP are you with ?
Sounds like you are being throttled more so if you have tried many air servers.
60meg line sounds much like a service from Virgin broadband, I recall a thread here: https://airvpn.org/topic/9941-virgin-media-openvpn-fail/page-2
Where someone with 60meg had issues and was being throttled or AirVPN was partially responsible.
Also worth a try testing a trial from another VPN provider, and see if you can get max speeds this was suggested over on that thread above.
Very slow here as well on all four UK exits, very disappointing as I signed up for AirVPN trusting it on some excellent reviews indicating great UK speeds...
I'm in the UK and have been using the servers for over a year now and have never had any problems regarding speed, so it sounds like a configuration problem or something to me.
Connect to the servers that come nearest the top of the list in the AirVPN client as those are the ones with the fastest ping response. I personally find the German servers much faster than the UK ones. Although obviously I think something needs to be sorted here as the UK servers *should* be the fastest from this location.
