Not connected, Your IP: 3.138.141.202
FXO750
Unstable connection using Airvpn with BT Wifi
When I'm connecting to BT Wifi, the connection is fairly fast and stable. But as soon as I am connecting to Airvpn (any server), the connection becomes unstable, i.e. full speed for two seconds, 30 seconds nothing, full speed for two seconds....etc. I used port 443 (udp and tcp).
I suspect it has something to do with BT Wifi but not sure what it is as they actually recommending to use a VPN when being connected to them.
Are you on Windows using the AirVPN client? Could you post the logs? Maybe try tcp 80 and udp 53.
