Not connected, Your IP: 3.140.242.165
Ubuntu 12.04 LTS stunnel and ssl configs not working
Hi Guys,
I am running Ubuntu 12.04 lts x86_64 and I have installed everything correctly and vpn works on all other configurations except for openvpn over ssl.
when I use the command stunnel (see below) it gives me an openvpn error failed to initialize SSL I'm pretty frustrated trying to get this to work with gnome network manager or openvpn directly. can someone help?
Thank you.
stunnel AirVPN_US-Librae_SSL-443.ssl
Clients allowed=500
stunnel 4.56 on x86_64-unknown-linux-gnu platform
Compiled/running with OpenSSL 1.0.1 14 Mar 2012
Threading:PTHREAD Sockets:POLL,IPv6 SSL:ENGINE,OCSP,FIPS
Reading configuration from file AirVPN_US-Librae_SSL-443.ssl
FIPS_mode_set: F06D065: error:0F06D065:common libcrypto routines:FIPS_mode_set:fips mode not supported
Line 13: "[openvpn]": Failed to initialize SSL
str_stats: 4 block(s), 57 data byte(s), 232 control byte(s)
