Not connected, Your IP: 18.117.165.66
mmgjp
ANSWERED Help configuring AirVPN on an DD-WRT router
Hello.
I give up trying to setup a router with DD-WRT. Each time I turn it on I have to configure a new server because it can't connect to the one already set (TLS handshake failed, Certificate is not valid, unreachable address, I get something different each time).
I followed the instructions in the site (https://airvpn.org/ddwrt/), downloaded configuration for various servers, but either it takes a long to get one that connects, or can't connect to any US server at all. I'm not blaming anyone here, it's just that it's frustrating.
This is the error I'm getting this time>
Serverlog Clientlog 19700101 00:05:14 Socket Buffers: R=[114688->131072] S=[114688->131072]
19700101 00:05:14 Data Channel MTU parms [ L:1557 D:1450 EF:57 EB:4 ET:0 EL:0 ]
19700101 00:05:14 Local Options String: 'V4 dev-type tun link-mtu 1557 tun-mtu 1500 proto UDPv4 cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
19700101 00:05:14 Expected Remote Options String: 'V4 dev-type tun link-mtu 1557 tun-mtu 1500 proto UDPv4 cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
19700101 00:05:14 Local Options hash (VER=V4): '2dd3fcaf'
19700101 00:05:14 Expected Remote Options hash (VER=V4): '8114d01c'
19700101 00:05:14 I UDPv4 link local: [undef]
19700101 00:05:14 I UDPv4 link remote: 149.255.33.154:443
19700101 00:05:14 N TLS Error: Unroutable control packet received from 149.255.33.154:443 (si=3 op=P_CONTROL_V1)
19700101 00:05:14 TLS: Initial packet from 149.255.33.154:443 sid=af161817 640bb8c2
19700101 00:05:15 N TLS Error: Unroutable control packet received from 149.255.33.154:443 (si=3 op=P_CONTROL_V1)
19700101 00:05:16 N VERIFY ERROR: depth=1 error=certificate is not yet valid:/C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
19700101 00:05:16 N TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:lib(20):func(144):reason(134)
19700101 00:05:16 N TLS Error: TLS object -> incoming plaintext read error
19700101 00:05:16 N TLS Error: TLS handshake failed
19700101 00:05:16 TCP/UDP: Closing socket
19700101 00:05:16 I SIGUSR1[soft tls-error] received process restarting
19700101 00:05:16 Restart pause 2 second(s)
19700101 00:05:18 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
19700101 00:05:18 I Re-using SSL/TLS context
19700101 00:05:18 Control Channel MTU parms [ L:1557 D:138 EF:38 EB:0 ET:0 EL:0 ]
19700101 00:05:18 Socket Buffers: R=[114688->131072] S=[114688->131072]
19700101 00:05:18 Data Channel MTU parms [ L:1557 D:1450 EF:57 EB:4 ET:0 EL:0 ]
19700101 00:05:18 Local Options String: 'V4 dev-type tun link-mtu 1557 tun-mtu 1500 proto UDPv4 cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
19700101 00:05:18 Expected Remote Options String: 'V4 dev-type tun link-mtu 1557 tun-mtu 1500 proto UDPv4 cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
19700101 00:05:18 Local Options hash (VER=V4): '2dd3fcaf'
19700101 00:05:18 Expected Remote Options hash (VER=V4): '8114d01c'
19700101 00:05:18 I UDPv4 link local: [undef]
19700101 00:05:18 I UDPv4 link remote: 149.255.33.154:443
19700101 00:05:18 N TLS Error: Unroutable control packet received from 149.255.33.154:443 (si=3 op=P_CONTROL_V1)
19700101 00:05:18 N TLS Error: Unroutable control packet received from 149.255.33.154:443 (si=3 op=P_ACK_V1)
19700101 00:05:20 N TLS Error: Unroutable control packet received from 149.255.33.154:443 (si=3 op=P_CONTROL_V1)
I've connected to this server successfully before.
Is there something I'm forgetting to setup on the router so once I can connect to a server and I turn the router off, the settings stay in it and next time it reconnects automatically?
Any help or guidance is very much appreciated.
Thank you very much in advance.
The most immediate problem we can see is that the date set in your router prevents authentication because in 1970 our certificates were not valid. Please set the correct date and time.
Dear staff:
Thank you for your quick response.
I should have noticed the date Sorry, never thought of it. I could connect now.
Does the actual configuration stays on the router after I turn it off?
Thanks again. Really saved the day.
very well. Yes, the configuration (but not necessarily the date and time) stays. You might like to have your router connect to an NTP server to sync date and time at each reboot or periodically.
