Not connected, Your IP: 18.224.0.25
dwright
Sudden connection problems
So just this evening I've been unable to connect. Here is the log file of a failure:
Sat Nov 02 19:33:23 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013
Enter Management Password:
Sat Nov 02 19:33:23 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25359
Sat Nov 02 19:33:23 2013 Need hold release from management interface, waiting...
Sat Nov 02 19:33:24 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25359
Sat Nov 02 19:33:24 2013 MANAGEMENT: CMD 'state on'
Sat Nov 02 19:33:24 2013 MANAGEMENT: CMD 'log all on'
Sat Nov 02 19:33:24 2013 MANAGEMENT: CMD 'hold off'
Sat Nov 02 19:33:24 2013 MANAGEMENT: CMD 'hold release'
Sat Nov 02 19:33:24 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sat Nov 02 19:33:24 2013 UDPv4 link local: [undef]
Sat Nov 02 19:33:24 2013 UDPv4 link remote: [AF_INET]109.163.230.232:443
Sat Nov 02 19:33:24 2013 MANAGEMENT: >STATE:1383420804,WAIT,,,
Sat Nov 02 19:33:30 2013 MANAGEMENT: >STATE:1383420810,AUTH,,,
Sat Nov 02 19:33:30 2013 TLS: Initial packet from [AF_INET]109.163.230.232:443, sid=a79f2532 df82ecb1
Sat Nov 02 19:33:30 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sat Nov 02 19:33:30 2013 VERIFY OK: nsCertType=SERVER
Sat Nov 02 19:33:30 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sat Nov 02 19:33:32 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Nov 02 19:33:32 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 02 19:33:32 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Nov 02 19:33:32 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 02 19:33:32 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sat Nov 02 19:33:32 2013 [server] Peer Connection Initiated with [AF_INET]109.163.230.232:443
Sat Nov 02 19:33:33 2013 MANAGEMENT: >STATE:1383420813,GET_CONFIG,,,
Sat Nov 02 19:33:34 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Sat Nov 02 19:33:34 2013 AUTH: Received control message: AUTH_FAILED
Sat Nov 02 19:33:34 2013 SIGUSR1[soft,auth-failure] received, process restarting
Sat Nov 02 19:33:34 2013 MANAGEMENT: >STATE:1383420814,RECONNECTING,auth-failure,,
Sat Nov 02 19:33:34 2013 Restart pause, 2 second(s)
Sat Nov 02 19:33:36 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sat Nov 02 19:33:36 2013 UDPv4 link local: [undef]
Sat Nov 02 19:33:36 2013 UDPv4 link remote: [AF_INET]109.163.230.232:443
Sat Nov 02 19:33:36 2013 MANAGEMENT: >STATE:1383420816,WAIT,,,
Sat Nov 02 19:33:36 2013 MANAGEMENT: >STATE:1383420816,AUTH,,,
Sat Nov 02 19:33:36 2013 TLS: Initial packet from [AF_INET]109.163.230.232:443, sid=79c9d0f3 07620168
Sat Nov 02 19:33:42 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sat Nov 02 19:33:42 2013 VERIFY OK: nsCertType=SERVER
Sat Nov 02 19:33:42 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sat Nov 02 19:33:43 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Nov 02 19:33:43 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 02 19:33:43 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Nov 02 19:33:43 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 02 19:33:43 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sat Nov 02 19:33:43 2013 [server] Peer Connection Initiated with [AF_INET]109.163.230.232:443
Sat Nov 02 19:33:44 2013 MANAGEMENT: >STATE:1383420824,GET_CONFIG,,,
Sat Nov 02 19:33:45 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Sat Nov 02 19:33:45 2013 AUTH: Received control message: AUTH_FAILED
Sat Nov 02 19:33:45 2013 SIGUSR1[soft,auth-failure] received, process restarting
Sat Nov 02 19:33:45 2013 MANAGEMENT: >STATE:1383420825,RECONNECTING,auth-failure,,
Sat Nov 02 19:33:45 2013 Restart pause, 2 second(s)
Sat Nov 02 19:33:45 2013 MANAGEMENT: CMD 'auth-retry none'
Sat Nov 02 19:33:47 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sat Nov 02 19:33:47 2013 UDPv4 link local: [undef]
Sat Nov 02 19:33:47 2013 UDPv4 link remote: [AF_INET]109.163.230.232:443
Sat Nov 02 19:33:47 2013 MANAGEMENT: >STATE:1383420827,WAIT,,,
Sat Nov 02 19:33:47 2013 MANAGEMENT: >STATE:1383420827,AUTH,,,
Sat Nov 02 19:33:47 2013 TLS: Initial packet from [AF_INET]109.163.230.232:443, sid=6f729b76 b7557d38
Sat Nov 02 19:33:48 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sat Nov 02 19:33:48 2013 VERIFY OK: nsCertType=SERVER
Sat Nov 02 19:33:48 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sat Nov 02 19:33:49 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Nov 02 19:33:49 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 02 19:33:49 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Nov 02 19:33:49 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 02 19:33:49 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sat Nov 02 19:33:49 2013 [server] Peer Connection Initiated with [AF_INET]109.163.230.232:443
Sat Nov 02 19:33:50 2013 MANAGEMENT: >STATE:1383420830,GET_CONFIG,,,
Sat Nov 02 19:33:51 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Sat Nov 02 19:33:51 2013 AUTH: Received control message: AUTH_FAILED
Sat Nov 02 19:33:51 2013 SIGTERM received, sending exit notification to peer
Sat Nov 02 19:33:56 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Sat Nov 02 19:33:56 2013 SIGTERM[soft,exit-with-notification] received, process exiting
Sat Nov 02 19:33:56 2013 MANAGEMENT: >STATE:1383420836,EXITING,exit-with-notification,,
How to fix?
