Not connected, Your IP: 216.73.216.51
knicker
How to port-forward pfsense using airvpn
If you want to port-forward and not use the upnp in pfsense, then follow this instruction:
  • In the pfsense browser navigate to Firewall  ------> NAT -------> Port Forward Click on the Plus button and follow the instructions in the picture (in the Redirect Target IP section, fill in your client's IP (192.168.0.115 for example) running the program (utorrent for example)
  • In the port sections fill in the forwarded port created on the airvpn website
  • In the Filter rule association section select: create new associated filter rule (this will create a rule for the firewall automatically)
  • Click save and navigate to the Outbound tab and click on the lowest Plus button and follow instructions on the picture (in the Destination IP section, fill in your router's IP)
  • (in the Redirect Target IP section, fill in your client's IP (192.168.0.115 for example) running the program (utorrent for example)
  • Click Save
As you can see in the green light in the below picture, I'm connected: Up and running!
Good luck,
knicker
Thanks for this guide.  I just have one question.  If I have setup a port forward through the website to forward from say port 12345 to port 54321, which port do I need to list when you state "port created on the airvpn website".
Thanks!
Hi ! thanks for this how to :)
I have a question on the section
Outbound tab. When Knicker said "fill in your router's IP":  Is it the public Ip ? the airvpn Ip ? Le LAN Ip ?
Thanks and have a nice day ;)
