I'm triyng to connect to AirVPN over Tor, but after a succesful connection, in few seconds it disconnect, then do a new connection and another disconnection, and so on in an infinite loop.
What can be the problem?
I'm in a virtual machine with Windows XP, my network is behind a corporate router.
Please note that the Tor connection alone works perfectly.
This is my log:
Wed Oct 23 13:02:26 2013 OpenVPN 2.3.2 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [IPv6] built on Aug 22 2013
Enter Management Password:
Wed Oct 23 13:02:26 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25342
Wed Oct 23 13:02:26 2013 Need hold release from management interface, waiting...
Wed Oct 23 13:02:26 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25342
Wed Oct 23 13:02:26 2013 MANAGEMENT: CMD 'state on'
Wed Oct 23 13:02:26 2013 MANAGEMENT: CMD 'log all on'
Wed Oct 23 13:02:26 2013 MANAGEMENT: CMD 'hold off'
Wed Oct 23 13:02:26 2013 MANAGEMENT: CMD 'hold release'
Wed Oct 23 13:02:27 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Oct 23 13:02:27 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150
Wed Oct 23 13:02:27 2013 MANAGEMENT: >STATE:1382526147,TCP_CONNECT,,,
Wed Oct 23 13:02:27 2013 TCP connection established with [AF_INET]127.0.0.1:9150
Wed Oct 23 13:02:28 2013 TCPv4_CLIENT link local: [undef]
Wed Oct 23 13:02:28 2013 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9150
Wed Oct 23 13:02:28 2013 MANAGEMENT: >STATE:1382526148,WAIT,,,
Wed Oct 23 13:02:29 2013 MANAGEMENT: >STATE:1382526149,AUTH,,,
Wed Oct 23 13:02:29 2013 TLS: Initial packet from [AF_INET]127.0.0.1:9150, sid=239afa78 ac79025e
Wed Oct 23 13:02:37 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Wed Oct 23 13:02:37 2013 VERIFY OK: nsCertType=SERVER
Wed Oct 23 13:02:37 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Wed Oct 23 13:02:57 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Oct 23 13:02:57 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Oct 23 13:02:57 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Oct 23 13:02:57 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Oct 23 13:02:57 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Wed Oct 23 13:02:57 2013 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9150
Wed Oct 23 13:02:58 2013 MANAGEMENT: >STATE:1382526178,GET_CONFIG,,,
Wed Oct 23 13:02:59 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Oct 23 13:03:00 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.4.6 10.5.4.5'
Wed Oct 23 13:03:00 2013 OPTIONS IMPORT: timers and/or timeouts modified
Wed Oct 23 13:03:00 2013 OPTIONS IMPORT: LZO parms modified
Wed Oct 23 13:03:00 2013 OPTIONS IMPORT: --ifconfig/up options modified
Wed Oct 23 13:03:00 2013 OPTIONS IMPORT: route options modified
Wed Oct 23 13:03:00 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Wed Oct 23 13:03:00 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Wed Oct 23 13:03:00 2013 MANAGEMENT: >STATE:1382526180,ASSIGN_IP,,10.5.4.6,
Wed Oct 23 13:03:00 2013 open_tun, tt->ipv6=0
Wed Oct 23 13:03:00 2013 TAP-WIN32 device [Connessione alla rete locale (LAN) 2] opened: \\.\Global\{ADB74DBD-312B-4C68-8F59-C7C6392A1827}.tap
Wed Oct 23 13:03:00 2013 TAP-Windows Driver Version 9.9
Wed Oct 23 13:03:00 2013 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.4.6/255.255.255.252 on interface {ADB74DBD-312B-4C68-8F59-C7C6392A1827} [DHCP-serv: 10.5.4.5, lease-time: 31536000]
Wed Oct 23 13:03:00 2013 Successful ARP Flush on interface [3] {ADB74DBD-312B-4C68-8F59-C7C6392A1827}
Wed Oct 23 13:03:05 2013 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Wed Oct 23 13:03:05 2013 C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 10.65.<removed>
Wed Oct 23 13:03:05 2013 ROUTE: route addition failed using CreateIpForwardEntry: Parametro non corretto. [status=87 if_index=2]
Wed Oct 23 13:03:05 2013 Route addition via IPAPI failed [adaptive]
Wed Oct 23 13:03:05 2013 Route addition fallback to route.exe
Wed Oct 23 13:03:05 2013 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Wed Oct 23 13:03:05 2013 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.4.5
Wed Oct 23 13:03:05 2013 Route addition via IPAPI succeeded [adaptive]
Wed Oct 23 13:03:05 2013 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.4.5
Wed Oct 23 13:03:05 2013 MANAGEMENT: >STATE:1382526185,ADD_ROUTES,,,
Wed Oct 23 13:03:05 2013 C:\WINDOWS\system32\route.exe ADD 10.5.0.1 MASK 255.255.255.255 10.5.4.5
Wed Oct 23 13:03:05 2013 Initialization Sequence Completed
Wed Oct 23 13:03:05 2013 MANAGEMENT: >STATE:1382526185,CONNECTED,SUCCESS,10.5.4.6,127.0.0.1
Wed Oct 23 13:03:46 2013 Connection reset, restarting [0]
Wed Oct 23 13:03:46 2013 C:\WINDOWS\system32\route.exe DELETE 10.5.0.1 MASK 255.255.255.255 10.5.4.5
Wed Oct 23 13:03:46 2013 Route deletion via IPAPI succeeded [adaptive]
Wed Oct 23 13:03:46 2013 C:\WINDOWS\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 10.65.<removed>
Wed Oct 23 13:03:46 2013 ROUTE: route deletion failed using DeleteIpForwardEntry: Parametro non corretto.
Wed Oct 23 13:03:46 2013 Route deletion via IPAPI failed [adaptive]
Wed Oct 23 13:03:46 2013 Route deletion fallback to route.exe
Wed Oct 23 13:03:46 2013 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Wed Oct 23 13:03:47 2013 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.5.4.5
Wed Oct 23 13:03:47 2013 Route deletion via IPAPI succeeded [adaptive]
Wed Oct 23 13:03:47 2013 C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.5.4.5
Wed Oct 23 13:03:47 2013 Closing TUN/TAP interface
Wed Oct 23 13:03:47 2013 SIGUSR1[soft,connection-reset] received, process restarting
Wed Oct 23 13:03:47 2013 MANAGEMENT: >STATE:1382526227,RECONNECTING,connection-reset,,
Wed Oct 23 13:03:47 2013 Restart pause, 5 second(s)
Thanks for your suggestions.
