JPizzle 1 Posted ... I'm having probems with port forwarding on a dd-wrt router. Using P2P, client is set to use same port as is configured on airvpn site but I'm getting port closed on my side and error 111 when running the port forward test on airvpn site.I see posts in the forum about putting forwarding commands in IPTABLES but then I also see warnings not to forward ports on my router here - https://airvpn.org/ports/ confused as to what I should do to correct this issue. thanks Quote Share this post Link to post
Staff 9759 Posted ... Hello! Please check your firewall, usually error 111 (assuming that your p2p client is running while the test is performed, of course) suggests a firewall problem. Kind regards Quote Share this post Link to post
JPizzle 1 Posted ... I don't see anything that should affect the connection in my firewall settings. see attached screenshotam I missing something? Quote Share this post Link to post
