rmoff
ANSWERED Connecting fails - TCP Connect - loops.
I'm trying to connect to airvpn using wifi on a train (East Coast). Many ports seemed to be blocked, but earlier I got it working using TCP port 443. Now (and previously) it just seems to loop "Making TCP connection". What would be causing this, and what workaround options do I have? I have tried other ports and UDP too.
thanks.
2013-09-30 11:56:17 *Tunnelblick: OS X 10.8.2; Tunnelblick 3.3.0 (build 3518); prior version 3.3beta56 (build 3515)
2013-09-30 11:56:17 *Tunnelblick: Attempting connection with AirVPN_Europe_TCP-443; Set nameserver = 1; monitoring connection
2013-09-30 11:56:17 *Tunnelblick: openvpnstart start AirVPN_Europe_TCP-443.tblk 1337 1 0 3 0 305 -atADGNWradsgnw
2013-09-30 11:56:17 *Tunnelblick: openvpnstart log:
     Loading tun.kext
     OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
          /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn
          --cd
          /Library/Application Support/Tunnelblick/Shared/AirVPN_Europe_TCP-443.tblk/Contents/Resources
          --daemon
          --management
          127.0.0.1
          1337
          --config
          /Library/Application Support/Tunnelblick/Shared/AirVPN_Europe_TCP-443.tblk/Contents/Resources/config.ovpn
          --log
          /Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-SAirVPN_Europe_TCP--443.tblk-SContents-SResources-Sconfig.ovpn.1_0_3_0_305.1337.openvpn.log
          --management-query-passwords
          --management-hold
          --script-security
          2
          --up
          /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw
          --down
          /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw
          --up-restart
2013-09-30 11:56:17 *Tunnelblick: Established communication with OpenVPN
2013-09-30 11:56:17 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Jul 22 2013
2013-09-30 11:56:17 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2013-09-30 11:56:17 Need hold release from management interface, waiting...
2013-09-30 11:56:17 MANAGEMENT: Client connected from 127.0.0.1:1337
2013-09-30 11:56:17 MANAGEMENT: CMD 'pid'
2013-09-30 11:56:17 MANAGEMENT: CMD 'state on'
2013-09-30 11:56:17 MANAGEMENT: CMD 'state'
2013-09-30 11:56:17 MANAGEMENT: CMD 'bytecount 1'
2013-09-30 11:56:17 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:17 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:17 LZO compression initialized
2013-09-30 11:56:17 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:17 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:17 MANAGEMENT: >STATE:1380538577,RESOLVE,,,
2013-09-30 11:56:17 *Tunnelblick: openvpnstart starting OpenVPN:
                    *                    /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Shared/AirVPN_Europe_TCP-443.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Shared/AirVPN_Europe_TCP-443.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-SAirVPN_Europe_TCP--443.tblk-SContents-SResources-Sconfig.ovpn.1_0_3_0_305.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --up-restart
2013-09-30 11:56:18 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:18 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:18 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:18 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:18 MANAGEMENT: >STATE:1380538578,TCP_CONNECT,,,
2013-09-30 11:56:19 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:19 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:19 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:19 MANAGEMENT: >STATE:1380538579,WAIT,,,
2013-09-30 11:56:19 Connection reset, restarting [0]
2013-09-30 11:56:19 TCP/UDP: Closing socket
2013-09-30 11:56:19 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:19 MANAGEMENT: >STATE:1380538579,RECONNECTING,connection-reset,,
2013-09-30 11:56:19 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:19 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:19 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:19 LZO compression initialized
2013-09-30 11:56:19 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:19 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:19 MANAGEMENT: >STATE:1380538579,RESOLVE,,,
2013-09-30 11:56:19 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:19 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:19 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:19 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:19 MANAGEMENT: >STATE:1380538579,TCP_CONNECT,,,
2013-09-30 11:56:20 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:20 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:20 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:20 MANAGEMENT: >STATE:1380538580,WAIT,,,
2013-09-30 11:56:20 Connection reset, restarting [0]
2013-09-30 11:56:20 TCP/UDP: Closing socket
2013-09-30 11:56:20 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:20 MANAGEMENT: >STATE:1380538580,RECONNECTING,connection-reset,,
2013-09-30 11:56:20 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:20 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:20 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:20 LZO compression initialized
2013-09-30 11:56:20 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:20 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:20 MANAGEMENT: >STATE:1380538580,RESOLVE,,,
2013-09-30 11:56:20 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:20 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:20 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:20 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:20 MANAGEMENT: >STATE:1380538580,TCP_CONNECT,,,
2013-09-30 11:56:21 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:21 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:21 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:21 MANAGEMENT: >STATE:1380538581,WAIT,,,
2013-09-30 11:56:21 Connection reset, restarting [0]
2013-09-30 11:56:21 TCP/UDP: Closing socket
2013-09-30 11:56:21 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:21 MANAGEMENT: >STATE:1380538581,RECONNECTING,connection-reset,,
2013-09-30 11:56:22 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:22 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:22 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:22 LZO compression initialized
2013-09-30 11:56:22 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:22 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:22 MANAGEMENT: >STATE:1380538582,RESOLVE,,,
2013-09-30 11:56:22 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:22 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:22 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:22 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:22 MANAGEMENT: >STATE:1380538582,TCP_CONNECT,,,
2013-09-30 11:56:23 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:23 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:23 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:23 MANAGEMENT: >STATE:1380538583,WAIT,,,
2013-09-30 11:56:23 Connection reset, restarting [0]
2013-09-30 11:56:23 TCP/UDP: Closing socket
2013-09-30 11:56:23 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:23 MANAGEMENT: >STATE:1380538583,RECONNECTING,connection-reset,,
2013-09-30 11:56:23 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:23 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:23 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:23 LZO compression initialized
2013-09-30 11:56:23 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:23 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:23 MANAGEMENT: >STATE:1380538583,RESOLVE,,,
2013-09-30 11:56:23 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:23 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:23 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:23 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:23 MANAGEMENT: >STATE:1380538583,TCP_CONNECT,,,
2013-09-30 11:56:24 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:24 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:24 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:24 MANAGEMENT: >STATE:1380538584,WAIT,,,
2013-09-30 11:56:24 Connection reset, restarting [0]
2013-09-30 11:56:24 TCP/UDP: Closing socket
2013-09-30 11:56:24 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:24 MANAGEMENT: >STATE:1380538584,RECONNECTING,connection-reset,,
2013-09-30 11:56:24 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:24 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:24 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:24 LZO compression initialized
2013-09-30 11:56:24 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:24 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:24 MANAGEMENT: >STATE:1380538584,RESOLVE,,,
2013-09-30 11:56:24 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:24 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:24 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:24 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:24 MANAGEMENT: >STATE:1380538584,TCP_CONNECT,,,
2013-09-30 11:56:25 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:25 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:25 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:25 MANAGEMENT: >STATE:1380538585,WAIT,,,
2013-09-30 11:56:26 Connection reset, restarting [0]
2013-09-30 11:56:26 TCP/UDP: Closing socket
2013-09-30 11:56:26 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:26 MANAGEMENT: >STATE:1380538586,RECONNECTING,connection-reset,,
2013-09-30 11:56:26 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:26 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:26 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:26 LZO compression initialized
2013-09-30 11:56:26 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:26 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:26 MANAGEMENT: >STATE:1380538586,RESOLVE,,,
2013-09-30 11:56:26 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:26 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:26 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:26 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:26 MANAGEMENT: >STATE:1380538586,TCP_CONNECT,,,
2013-09-30 11:56:27 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:27 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:27 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:27 MANAGEMENT: >STATE:1380538587,WAIT,,,
2013-09-30 11:56:27 Connection reset, restarting [0]
2013-09-30 11:56:27 TCP/UDP: Closing socket
2013-09-30 11:56:27 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:27 MANAGEMENT: >STATE:1380538587,RECONNECTING,connection-reset,,
2013-09-30 11:56:27 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:27 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:27 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:27 LZO compression initialized
2013-09-30 11:56:27 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:27 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:27 MANAGEMENT: >STATE:1380538587,RESOLVE,,,
2013-09-30 11:56:27 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:27 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:27 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:27 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:27 MANAGEMENT: >STATE:1380538587,TCP_CONNECT,,,
2013-09-30 11:56:28 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:28 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:28 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:28 MANAGEMENT: >STATE:1380538588,WAIT,,,
2013-09-30 11:56:28 Connection reset, restarting [0]
2013-09-30 11:56:28 TCP/UDP: Closing socket
2013-09-30 11:56:28 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:28 MANAGEMENT: >STATE:1380538588,RECONNECTING,connection-reset,,
2013-09-30 11:56:28 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:28 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:28 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:28 LZO compression initialized
2013-09-30 11:56:28 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:28 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:28 MANAGEMENT: >STATE:1380538588,RESOLVE,,,
2013-09-30 11:56:28 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:28 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:28 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:28 Attempting to establish TCP connection with 67.215.66.132:443 [nonblock]
2013-09-30 11:56:28 MANAGEMENT: >STATE:1380538588,TCP_CONNECT,,,
2013-09-30 11:56:29 TCP connection established with 67.215.66.132:443
2013-09-30 11:56:29 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:29 TCPv4_CLIENT link remote: 67.215.66.132:443
2013-09-30 11:56:29 MANAGEMENT: >STATE:1380538589,WAIT,,,
2013-09-30 11:56:31 Connection reset, restarting [0]
2013-09-30 11:56:31 TCP/UDP: Closing socket
2013-09-30 11:56:31 SIGUSR1[soft,connection-reset] received, process restarting
2013-09-30 11:56:31 MANAGEMENT: >STATE:1380538591,RECONNECTING,connection-reset,,
2013-09-30 11:56:33 *Tunnelblick: No 'reconnecting.sh' script to execute
2013-09-30 11:56:33 MANAGEMENT: CMD 'hold release'
2013-09-30 11:56:33 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-09-30 11:56:33 LZO compression initialized
2013-09-30 11:56:33 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
2013-09-30 11:56:33 Socket Buffers: R=[131072->65536] S=[131072->65536]
2013-09-30 11:56:33 MANAGEMENT: >STATE:1380538593,RESOLVE,,,
2013-09-30 11:56:34 *Tunnelblick: Disconnecting; Disconnect button pressed
2013-09-30 11:56:34 *Tunnelblick: Disconnecting using 'killall'
2013-09-30 11:56:34 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
2013-09-30 11:56:34 Local Options hash (VER=V4): '958c5492'
2013-09-30 11:56:34 Expected Remote Options hash (VER=V4): '79ef4284'
2013-09-30 11:56:34 Attempting to establish TCP connection with 95.211.138.19:443 [nonblock]
2013-09-30 11:56:34 MANAGEMENT: >STATE:1380538594,TCP_CONNECT,,,
2013-09-30 11:56:35 TCP connection established with 95.211.138.19:443
2013-09-30 11:56:35 TCPv4_CLIENT link local: [undef]
2013-09-30 11:56:35 TCPv4_CLIENT link remote: 95.211.138.19:443
2013-09-30 11:56:35 TCP/UDP: Closing socket
2013-09-30 11:56:35 SIGTERM[hard,init_instance] received, process exiting
2013-09-30 11:56:35 MANAGEMENT: >STATE:1380538595,EXITING,init_instance,,
2013-09-30 11:56:36 *Tunnelblick: No 'post-disconnect.sh' script to execute
