Rileyk20 0 Posted ... Hello, I have seen other VPNs give you the option to choose your type of encryption. Would it be possible for AirVPN to make encryption level an option? Thank you. Quote Share this post Link to post
Staff 9761 Posted ... Hello! We're sorry, this option is not available. Kind regards Quote Share this post Link to post
Guest summoner23 Posted ... Do you have any plans to add this option? Also do you update the 2048 bit RSA key hourly to make it harder to decrypt? Quote Share this post Link to post
Staff 9761 Posted ... Hello! We have currently no plans to offer different types of encryption. TLS re-keying (Diffie-Hellman) is by default performed at each new connection AND every 60 minutes by default. You can lower this time, but you can not increase it, on the client side (please see OpenVPN manual). Kind regards Quote Share this post Link to post
Guest summoner23 Posted ... Hello! We have currently no plans to offer different types of encryption. TLS re-keying (Diffie-Hellman) is by default performed at each new connection AND every 60 minutes by default. You can lower this time, but you can not increase it, on the client side (please see OpenVPN manual). Kind regards So OPENVPN will update it every 60min even if i don't disconnect from the VPN? or does it only do it when i reconnect? Quote Share this post Link to post
Staff 9761 Posted ... Hello! We have currently no plans to offer different types of encryption. TLS re-keying (Diffie-Hellman) is by default performed at each new connection AND every 60 minutes by default. You can lower this time, but you can not increase it, on the client side (please see OpenVPN manual). Kind regards So OPENVPN will update it every 60min even if i don't disconnect from the VPN? or does it only do it when i reconnect? Hello, the re-keying occurs every 60 minutes as well. Kind regards Quote Share this post Link to post
