sk8erdude 0 Posted ... I am trying to set up AirVPN over TOR and it will not connect. Here are my logs. Thanks in advance for any and all help. 7/27/2013 - 9:44 PM AirVPN client version: 1.8 7/27/2013 - 9:44 PM Reading options from \AirVPN\Air\1.0.0.0\AirVPN.xml 7/27/2013 - 9:44 PM OpenVPN bundle version: OpenVPN 2.3.0 7/27/2013 - 9:44 PM OpenVPN current version: OpenVPN 2.3.0 7/27/2013 - 9:44 PM Login... 7/27/2013 - 9:44 PM Login success. 7/27/2013 - 9:45 PM Contacting service... 7/27/2013 - 9:45 PM Connecting... 7/27/2013 - 9:45 PM OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 7/27/2013 - 9:45 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 7/27/2013 - 9:45 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 7/27/2013 - 9:45 PM Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 7/27/2013 - 9:45 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 7/27/2013 - 9:45 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 7/27/2013 - 9:45 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) Quote Share this post Link to post
Staff 10380 Posted ... Hello, it seems that the TOR proxy is either not running or not listening to port 9050, can you please check? Latest TOR proxy bundled in the TBB listens to SocksPort 9150 by default. Kind regards Quote Share this post Link to post
judgemenot 0 Posted ... If you want to connect toAirVPN over TOR, you need to set your parameters to: SOCKS Proxy: 127.0.0.1Port: 9150 And it will work. I don't know why the default seems to fall to 9050, but if that was correct at one time, it no longer is. Try the Port: 9150. Good Luck! Quote Share this post Link to post
