ciub
tor issue
Hi i didn't understand this part
If you use the configuration generator, don't forget to download the archive air.zip, copy all the files inside it, and paste them into the OpenVPN configuration directory.
can you please explain me how to do that?
please access the Configuration Generator ("Client Area"-->"Config Generator") and follow the instructions.
After you have downloaded the files you wish, decompress the archive if necessary, copy the files and paste them in the appropriate directory. Since you wish to run OpenVPN directly on OS X in order to connect OpenVPN over TOR, just paste the files in any folder you like and follow the instructions for OS X for direct OpenVPN usage (you can't use Tunnelblick because it does not support connections of OpenVPN over a proxy):
https://airvpn.org/topic/9325-development-of-os-x-airvpn-client/
