murphsite
Ubuntu connection drop
Hi everyone,
I was using AirVPN for several month now on Mac OSX with Tunnelblick and it worked flawlessly.
No I have configured it on my Ubuntu laptop, all settings exactly like in the help section and here:
https://airvpn.org/?option=com_kunena&Itemid=55&func=view&catid=3&id=116
It works at first, AirVPN.org website tells me I'm connected, but just after a couple of seconds, I only get timeout errors.
I'm using the network-manager under Ubuntu.
Any idea?
murph
syslog:
3085 Jul 18 23:45:04 titan NetworkManager[1247]: <info> Starting VPN service 'openvpn'...
3086 Jul 18 23:45:04 titan NetworkManager[1247]: <info> VPN service 'openvpn' started (org.freedesktop.NetworkManager.openvpn), PID 14747
3087 Jul 18 23:45:04 titan NetworkManager[1247]: <info> VPN service 'openvpn' appeared; activating connections
3088 Jul 18 23:45:04 titan NetworkManager[1247]: <info> VPN plugin state changed: starting (3)
3089 Jul 18 23:45:04 titan NetworkManager[1247]: <info> VPN connection 'AirVPN_Germany_UDP-443' (Connect) reply received.
3090 Jul 18 23:45:05 titan nm-openvpn[14750]: OpenVPN 2.2.1 x86_64-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 2>
3091 Jul 18 23:45:05 titan nm-openvpn[14750]: WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html>
3092 Jul 18 23:45:05 titan nm-openvpn[14750]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
3093 Jul 18 23:45:05 titan nm-openvpn[14750]: WARNING: file '/home/thomas/Downloads/user.key' is group or others accessible
3094 Jul 18 23:45:05 titan nm-openvpn[14750]: LZO compression initialized
3095 Jul 18 23:45:05 titan nm-openvpn[14750]: RESOLVE: NOTE: de.airvpn.org resolves to 3 addresses
3096 Jul 18 23:45:05 titan nm-openvpn[14750]: UDPv4 link local: [undef]
3097 Jul 18 23:45:05 titan nm-openvpn[14750]: UDPv4 link remote: [AF_INET]46.165.208.65:443
3098 Jul 18 23:45:06 titan nm-openvpn[14750]: [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443
3099 Jul 18 23:45:08 titan nm-openvpn[14750]: TUN/TAP device tun0 opened
3100 Jul 18 23:45:08 titan nm-openvpn[14750]: /usr/lib/NetworkManager/nm-openvpn-service-openvpn-helper tun0 1500 1558 10.4.54.62 10.4.54.61 init
3101 Jul 18 23:45:08 titan NetworkManager[1247]:    SCPlugin-Ifupdown: devices added (path: /sys/devices/virtual/net/tun0, iface: tun0)
3102 Jul 18 23:45:08 titan NetworkManager[1247]:    SCPlugin-Ifupdown: device added (path: /sys/devices/virtual/net/tun0, iface: tun0): no ifupdown c>
3103 Jul 18 23:45:08 titan NetworkManager[1247]: <warn> /sys/devices/virtual/net/tun0: couldn't determine device driver; ignoring...
3104 Jul 18 23:45:08 titan NetworkManager[1247]: <info> VPN connection 'AirVPN_Germany_UDP-443' (IP4 Config Get) reply received from old-style plugin.
3105 Jul 18 23:45:08 titan NetworkManager[1247]: <info> VPN Gateway: 46.165.208.65
3106 Jul 18 23:45:08 titan NetworkManager[1247]: <info> Tunnel Device: tun0
3107 Jul 18 23:45:08 titan NetworkManager[1247]: <info> IPv4 configuration:
3108 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Internal Gateway: 10.4.54.61
3109 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Internal Address: 10.4.54.62
3110 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Internal Prefix: 32
3111 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Internal Point-to-Point Address: 10.4.54.61
3112 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Maximum Segment Size (MSS): 0
3113 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Static Route: 10.4.0.1/32   Next Hop: 10.4.0.1
3114 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Forbid Default Route: no
3115 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   Internal DNS: 10.4.0.1
3116 Jul 18 23:45:08 titan NetworkManager[1247]: <info>   DNS Domain: '(none)'
3117 Jul 18 23:45:08 titan NetworkManager[1247]: <info> No IPv6 configuration
3118 Jul 18 23:45:08 titan nm-openvpn[14750]: Initialization Sequence Completed
3119 Jul 18 23:45:09 titan NetworkManager[1247]: <info> VPN connection 'AirVPN_Germany_UDP-443' (IP Config Get) complete.
3120 Jul 18 23:45:09 titan NetworkManager[1247]: <info> Policy set 'AirVPN_Germany_UDP-443' (tun0) as default for IPv4 routing and DNS.
3121 Jul 18 23:45:09 titan NetworkManager[1247]: <info> Writing DNS information to /sbin/resolvconf
3122 Jul 18 23:45:09 titan dnsmasq[1628]: setting upstream servers from DBus
3123 Jul 18 23:45:09 titan dnsmasq[1628]: using nameserver 10.4.0.1#53
3124 Jul 18 23:45:09 titan NetworkManager[1247]: <info> VPN plugin state changed: started (4)
3125 Jul 18 23:45:09 titan dbus[1136]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
3126 Jul 18 23:45:09 titan dbus[1136]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
3127 Jul 18 23:45:16 titan ntpdate[14807]: adjust time server 91.189.94.4 offset -0.006050 sec
I can access about 4 URL's then, and then it breaks up.
If you need other logs I would be grateful for a hint where those are, I'm new to Ubuntu.
no apparent problem is showed in the logs. Does the same happen if you connect directly with OpenVPN?
Interesting!
When I run it manually as root, it seems to work, no hang up so far:
sudo openvpn --config AirVPN_Germany_UDP-443.ovpn
Thu Jul 25 02:03:54 2013 OpenVPN 2.2.1 x86_64-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Feb 13 2013
Thu Jul 25 02:03:54 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Thu Jul 25 02:03:54 2013 LZO compression initialized
Thu Jul 25 02:03:54 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Thu Jul 25 02:03:54 2013 Socket Buffers: R=[212992->131072] S=[212992->131072]
Thu Jul 25 02:03:54 2013 RESOLVE: NOTE: de.airvpn.org resolves to 3 addresses
Thu Jul 25 02:03:54 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Thu Jul 25 02:03:54 2013 Local Options hash (VER=V4): '22188c5b'
Thu Jul 25 02:03:54 2013 Expected Remote Options hash (VER=V4): 'a8f55717'
Thu Jul 25 02:03:54 2013 UDPv4 link local: [undef]
Thu Jul 25 02:03:54 2013 UDPv4 link remote: [AF_INET]46.165.208.65:443
Thu Jul 25 02:03:54 2013 TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=3750f0d5 81111afc
Thu Jul 25 02:03:54 2013 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Thu Jul 25 02:03:54 2013 VERIFY OK: nsCertType=SERVER
Thu Jul 25 02:03:54 2013 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Thu Jul 25 02:03:55 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Jul 25 02:03:55 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Jul 25 02:03:55 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Jul 25 02:03:55 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Jul 25 02:03:55 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Thu Jul 25 02:03:55 2013 [server] Peer Connection Initiated with [AF_INET]46.165.208.65:443
Thu Jul 25 02:03:57 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Jul 25 02:03:57 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.54.62 10.4.54.61'
Thu Jul 25 02:03:57 2013 OPTIONS IMPORT: timers and/or timeouts modified
Thu Jul 25 02:03:57 2013 OPTIONS IMPORT: LZO parms modified
Thu Jul 25 02:03:57 2013 OPTIONS IMPORT: --ifconfig/up options modified
Thu Jul 25 02:03:57 2013 OPTIONS IMPORT: route options modified
Thu Jul 25 02:03:57 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Jul 25 02:03:57 2013 ROUTE default_gateway=192.168.0.1
Thu Jul 25 02:03:57 2013 TUN/TAP device tun0 opened
Thu Jul 25 02:03:57 2013 TUN/TAP TX queue length set to 100
Thu Jul 25 02:03:57 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Jul 25 02:03:57 2013 /sbin/ifconfig tun0 10.4.54.62 pointopoint 10.4.54.61 mtu 1500
Thu Jul 25 02:03:57 2013 /sbin/route add -net 46.165.208.65 netmask 255.255.255.255 gw 192.168.0.1
Thu Jul 25 02:03:57 2013 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.54.61
Thu Jul 25 02:03:57 2013 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.54.61
Thu Jul 25 02:03:57 2013 /sbin/route add -net 10.4.0.1 netmask 255.255.255.255 gw 10.4.54.61
Thu Jul 25 02:03:57 2013 Initialization Sequence Completed
