catlady3030 4 Posted ... This started yesterday on two different servers. The AirVPN Client Upload speed skyrockets from 0kb/s to around 33,000kb/s and the "Session Upload" subsequently skyrockets as well, even when I completely disconnected from the internet. Quote Share this post Link to post
Staff 10459 Posted ... Hello, maybe some system process is sending a lot of data on the internal network or to the machine itself, or it is a bug. Would you be able to detect if there's any application causing the spike? Kind regards Quote Share this post Link to post
catlady3030 4 Posted ... The upload spike continued even when all programs were closed and I was completely disconnected from the network (wi-fi turned off). The upload bandwidth also did not register with my ISP's bandwidth monitoring. Quote Share this post Link to post
Staff 10459 Posted ... Hello, that hints to some Air client bug. If this is a major problem, can you please try a connection through OpenVPN GUI? Can you also tell use your exact Windows version? Kind regards Quote Share this post Link to post
