shooterroot
block all conected, if not vpn.
As it is better to block all connections if there is no connection on vpn. For me it is better to start in an aaplet for this purpose.
To adjust firewall doesn't approach, it is necessary not always.
Help, can will make a simple bat-file for this purpose.Also it was possible to unblock connections if it is necessary.
Most not to understand. OS - windows.
We recommend to set firewall rules for that purpose.
Anyway, the alternative you're looking for does exist. Just use small programs like VPNLifeGuard, VPNCheck or VPNetMon. They will forcefully kill the programs you tell them if the VPN connection drops
AirVPN admins
