tharrisone 2 Posted ... It repeats this over and over but I haven't had any problems using your service up to now. Sun Jun 23 17:00:18 2013 OpenVPN 2.2.1 x86_64-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Feb 13 2013Sun Jun 23 17:00:18 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executablesSun Jun 23 17:00:18 2013 LZO compression initializedSun Jun 23 17:00:18 2013 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]Sun Jun 23 17:00:18 2013 Socket Buffers: R=[87380->131072] S=[16384->131072]Sun Jun 23 17:00:18 2013 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]Sun Jun 23 17:00:18 2013 Local Options hash (VER=V4): '958c5492'Sun Jun 23 17:00:18 2013 Expected Remote Options hash (VER=V4): '79ef4284'Sun Jun 23 17:00:18 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1413 [nonblock]Sun Jun 23 17:00:18 2013 TCP connection established with [AF_INET]127.0.0.1:1413Sun Jun 23 17:00:18 2013 TCPv4_CLIENT link local: [undef]Sun Jun 23 17:00:18 2013 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:14132013.06.23 17:00:18 LOG5[2676:140584081340160]: Service [openvpn] accepted connection from 127.0.0.1:579342013.06.23 17:00:18 LOG6[2676:140584081340160]: connect_blocking: connecting 31.193.12.100:4432013.06.23 17:00:20 LOG3[2676:140584081340160]: connect_blocking: connect 31.193.12.100:443: Connection refused (111)2013.06.23 17:00:20 LOG5[2676:140584081340160]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socketSun Jun 23 17:00:20 2013 Connection reset, restarting [-1]Sun Jun 23 17:00:20 2013 TCP/UDP: Closing socketSun Jun 23 17:00:20 2013 SIGUSR1[soft,connection-reset] received, process restarting 1 Irrardblase reacted to this Quote Share this post Link to post
Staff 10338 Posted ... Hello, your account is now successfully connected, is it alright now? Kind regards Quote Share this post Link to post
tharrisone 2 Posted ... I connected to another server so it must be related to that server itself. Quote Share this post Link to post
Staff 10338 Posted ... Thanks! We'll investigate on Cassiopeia. Kind regards Quote Share this post Link to post
Dosenfleisch 4 Posted ... I am also getting this continual loop. Secondly, I cannot find a list of commands to control stunnel once the service is initiated and stops looping. Would appreciate your assistance. Quote Share this post Link to post
Dosenfleisch 4 Posted ... SOLVED: I am also getting this continual loop. Secondly, I cannot find a list of commands to control stunnel once the service is initiated and stops looping. Would appreciate your assistance.The loop was isolated to a single server, and the commands I eventually uncovered. Quote Share this post Link to post
