It was either a hard or soft reset of the server due to a power wattage->caused a reboot of Chepei Canadian server->caused stunnel to restart/malfunction on the server now it is back to normal. (until it reboots again I assume)
stunnel 4.56 with OpenVpn over SSL working on Cephei now.
Putty SSH-22 working....
UDP 443 working.....
TCP 443 working....
Regards,
Flex
Admins and Moderators
Microsoft Office 2013 Plus Preview might also play a role in this. Outlook 2013 Preview in particular when configured for Hotmail/Yahoo/Gmail etc. Somehow and for some odd reason the connection is dropped. My OpenVpn 2.2.2 over SSL-443 dropped out of the blue when sending/receiving emails.
Advise members to uninstall Microsoft Office 2013 Plus Preview.
Microsoft Office 2010 is OK.
Regards,
Flex
Hi All,
Therefore noone could login into gmail/yahoo/hotmail or
https websites(e.g.https://www.google.com) due to "Error 107 aka SSL protocol issue"(the so called certificate problem).
Problem seems to be attributed to:
1.Hacking of the hosts file in Windows.
2.Adobe
3.Some Antivirus they use(d).
4.Malicious Website(s) they visited.
5.None of the above are certain.
Fixes/Solutions can be found online:
1.Webroot  claims to be able to correct the problem/glitch.
2.Change IE/Chrome/Firefox settings to SSL3.0/TLS1.0 and http://www.google.com->https://www.goggle.com
Regards,
Flex
tested and running:
stunnel 4.56 with OpenVpn 2.2.2 over SSL
TCP and UDP 443
Putty SSH-22 with OpenVpn 2.2.2
THIS IS REGARDING INTERNET/BROWSER CONFIGURATION:
https://airvpn.org domain/website uses TLS 1.0
https://google.com domain/website uses TLS 1.1...it will connect just fine with SSL3.0/TLS1.0 ENABLED .....
Regards,
Flex
