doublex 0 Posted ... Hey, i tried to set up an openvpn server on my tp-link 1043n with dd-wrt :DD-WRT v24-sp2 (05/27/13) std(SVN revision 21676) but as u can see in the log, the connection always failed. my settings, the log and the content of the config file is attached. thank you !doublexconfig.txt Quote Share this post Link to post
Staff 10307 Posted ... Hello! There are multiple problems. If you wish to access an Air server, your OpenVPN will have to work in "client mode", not in server mode. In this case, the destination port, the encryption cipher, the hash algorithm, the client certificate, the server certificate, the key, the DH PEM, the configuration file, the VPN server entry-IP address are wrong. Additionally, account "doublex" is not authorized to access any Air VPN server because it lacks a subscription. Never been subscribed before, it also lacks a key (which will be generated with a subscription). Once the account has a subscription, generate certificates, configuration file and key with our Configuration Generator and follow this guide:https://airvpn.org/ddwrt to configure OpenVPN as a client. We do not provide specific support to set up an OpenVPN server, but you can find several good guides on the Internet. Kind regards Quote Share this post Link to post
