choq 7 Posted ... Hi, When running airvpn, kerberos port stays open. I know it is used for encryption (openvpn?), but is this a normal situation using airvpn, linux and iptables? Quote Share this post Link to post
Staff 10423 Posted ... Hello, no, port 88 is never forwarded to OpenVPN clients, it is always closed for them. Kind regards Quote Share this post Link to post
gtu1204 0 Posted ... Hello, I have the same problem...port 88 (kerberos) stays open when running Airvpn (grc shieldsup test) I'm using Linux Mint 17.1 and windows 7...same problem in both cases with airvpn client software The shieldup test is totally ok when not using airvpn in both cases Where's the problem ? Quote Share this post Link to post
Staff 10423 Posted ... Hello, I have the same problem...port 88 (kerberos) stays open when running Airvpn (grc shieldsup test) I'm using Linux Mint 17.1 and windows 7...same problem in both cases with airvpn client software The shieldup test is totally ok when not using airvpn in both cases Where's the problem ? Hello! There is no problem: have you read the thread? Kind regards Quote Share this post Link to post
