budweiser 2 Posted ... (edited) Hi! I have set a DDNS yesterday evening, but all DNS servers are still showing red/wrong and some show EMPTY/or another IP with red numbers.Have I made a mistake? Cheers! EDIT: Does DDNS also means, that even if I change servers for whatever reason, the DNS will remain the same (i am running a private FTP server) Thanx Edited ... by budweiser Quote Share this post Link to post
Staff 10466 Posted ... Hello! Thanks, problem fixed! There were huge delays in DDNS updates. You should see now quick updates as usual. Kind regards 1 budweiser reacted to this Quote Share this post Link to post
Staff 10466 Posted ... EDIT: Does DDNS also means, that even if I change servers for whatever reason, the DNS will remain the same (i am running a private FTP server) Thanx Hello! Yes, the service is meant to give you domain names that are consistent and persistent across all Air servers. Kind regards Quote Share this post Link to post
