wintersnow
ANSWERED More than one openVPN icon on an iPad?
I'd like to be able to choose from two servers when I log in to air VPN on my iPad. I set up one. Can I add another? If so, do I follow the same procedure and rename the second icon "server 2"after it's created or is there some other procedure I should follow?
Thanks.
