esflovian
Site says "not connected," but I'm fairly certain that I am
The red box at the bottom of this page is telling me that I'm not connected, and it is showing me on my normal router IP - even though I am connected through the AirVPN client. If I go to an IP lookup website (like http://ip-lookup.net/), it gives me the IP I am connected to through AirVPN. I'm just a bit confused as to why this is happening.
Any ideas? I found this forum post from last month but that's about all I could find. Thanks
Hi there,
Here you go:
5/14/2013 - 7:10 PM AirVPN client version: 1.8
5/14/2013 - 7:10 PM Reading options from C:\Users\[name redacted]\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
5/14/2013 - 7:10 PM OpenVPN bundle version: OpenVPN 2.3.0
5/14/2013 - 7:10 PM OpenVPN current version: OpenVPN 2.3.0
5/14/2013 - 7:10 PM Ready.
5/14/2013 - 7:10 PM Login...
5/14/2013 - 7:11 PM Login success.
5/14/2013 - 7:11 PM Contacting service...
5/14/2013 - 7:11 PM Connecting...
5/14/2013 - 7:11 PM OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan  8 2013
5/14/2013 - 7:11 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/14/2013 - 7:11 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/14/2013 - 7:11 PM UDPv4 link local: [undef]
5/14/2013 - 7:11 PM UDPv4 link remote: [AF_INET]108.59.8.142:443
5/14/2013 - 7:11 PM TLS: Initial packet from [AF_INET]108.59.8.142:443, sid=47b34e71 8a30fa69
5/14/2013 - 7:11 PM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
5/14/2013 - 7:11 PM VERIFY OK: nsCertType=SERVER
5/14/2013 - 7:11 PM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
5/14/2013 - 7:11 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/14/2013 - 7:11 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/14/2013 - 7:11 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/14/2013 - 7:11 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/14/2013 - 7:11 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
5/14/2013 - 7:11 PM [server] Peer Connection Initiated with [AF_INET]108.59.8.142:443
5/14/2013 - 7:11 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
5/14/2013 - 7:11 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.23.134 10.4.23.133'
5/14/2013 - 7:11 PM OPTIONS IMPORT: timers and/or timeouts modified
5/14/2013 - 7:11 PM OPTIONS IMPORT: LZO parms modified
5/14/2013 - 7:11 PM OPTIONS IMPORT: --ifconfig/up options modified
5/14/2013 - 7:11 PM OPTIONS IMPORT: route options modified
5/14/2013 - 7:11 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
5/14/2013 - 7:11 PM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
5/14/2013 - 7:11 PM open_tun, tt->ipv6=0
5/14/2013 - 7:11 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{5AADBBC4-5D43-4571-8856-C2CCB3FA3637}.tap
5/14/2013 - 7:11 PM TAP-Windows Driver Version 9.9
5/14/2013 - 7:11 PM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.23.134/255.255.255.252 on interface {5AADBBC4-5D43-4571-8856-C2CCB3FA3637} [DHCP-serv: 10.4.23.133, lease-time: 31536000]
5/14/2013 - 7:11 PM Successful ARP Flush on interface [26] {5AADBBC4-5D43-4571-8856-C2CCB3FA3637}
5/14/2013 - 7:11 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
5/14/2013 - 7:11 PM C:\Windows\system32\route.exe ADD 108.59.8.142 MASK 255.255.255.255 192.168.2.1
5/14/2013 - 7:11 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
5/14/2013 - 7:11 PM Route addition via IPAPI succeeded [adaptive]
5/14/2013 - 7:11 PM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.23.133
5/14/2013 - 7:11 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
5/14/2013 - 7:11 PM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.23.133
5/14/2013 - 7:11 PM C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.23.133
5/14/2013 - 7:11 PM Initialization Sequence Completed
5/14/2013 - 7:11 PM Starting Management Interface...
5/14/2013 - 7:11 PM Checking...
5/14/2013 - 7:11 PM Retrieve statistics...
5/14/2013 - 7:11 PM Connected.
Note that on line 2 I removed my name and replaced it with "[name redacted]".
