thebeat 1 Posted ... Hi, just making sure one last time that my connection doesn't 'leak' my real ip at anytime.. Here is what i've done so far: -set the following comodo rule for utorrent Allow IP In/Out From IP In [10.4.0.0 - 10.9.255.255] To MAC Any Where Protocol Is AnyAllow IP In/Out From MAC Any To IP In [10.4.0.0.0 - 10.9.255.255] Where Protocol Is AnyBlock IP In/Out From MAC Any To MAC Any Where Protocol Is Any -Run the file generated from checkmytorrentip.com for at least 24H -Change the DNS setting with air vpn ones(10.4.0.1 and 10.5.0.1) -check for DNS leak at dnsleaktest.com -check for ip leak at ipleak.net Is it enough or there is something else i should i do? Thanks;-) Quote Share this post Link to post
Staff 10307 Posted ... Hello! We confirm that your configuration prevents DNS leaks and uTorrent leaks. Kind regards Quote Share this post Link to post
joker69 0 Posted ... I have just been using dns settings and airvpn. Would utorrent still leak my IP? Quote Share this post Link to post
thebeat 1 Posted ... Hello! We confirm that your configuration prevents DNS leaks and uTorrent leaks. Kind regards Thanks! Gotta say that so far air vpn support has nothing short of amazing.. Thank you!!! Quote Share this post Link to post
